Car Coding
#641
My Ride: 550i SMG, HUD, Cold Weather/Sport Package, Mtech front bumper, Oem M5 rear bumper, V1 Concealed, RPI Scoop, 6000K HID both Fog and Headlight, M5 mirrors, LED interior lighting, M5 SMG Shift Knob, Eisenmann Sport Exhaust Quad Pipe, 30% Tint, Sprint B
I have upgraded to the CIC system in my car. I am trying to program some features on the new CIC. SO far I have been able to update the order and have successfully coded the KOMBI module. When I try to code the CIC module I get the following message below when it tries to read the ecu: (I am using the latest bmw standard tools and have updated the daten files to v42) Any guidance on solving this problem?
error in cabd! look at cabi.err and error.log!
COAPI-2041:wrong ecu coding index
A_CIC: CODIERINDEX = 1ah
#642
This means that you don't have the daten file that was programmed into your CIC. e.g. An E90 file was programmed into your CIC but you are trying to code using the E60 chassis that doesn't have that version. Or your CIC was flashed with a higher version than the daten files in your coding directories.
#643
Is there a method to check to see if the e90 module was programmed into the cic with loading the e90 daten files.
#644
My Ride: 2006 Alpine White M5
Well thanks for the help everyone, finally got NCS Expert up and running. Have coded a few fun things into my car.
Only trouble I'm still having is when I try to read the LMA or KGM modules. Both give me an error. In the error log, it points to a file that is present in the daten folder. Any reason why this is happening with just these 2 modules?
John
John
#646
Can anyone tell me which acronym is for the "tractor" module? I've looked on the list of modules but couldn't find it. I want to do the following...
[Entry aid steering wheel height adjustment de-/activate]
Control unit: tractor
EINSTIEGSHILFE_HOEHE
active -> nicht_aktiv
#647
Engine: N54
#650
Any idea how to find newer "daten" files?
