Car Coding
Old 03-03-2011, 02:30 PM
  #421
BlaSTiWi's Avatar
I got it!!! Tkx so much for NoQuarter ... I went thru his trace file line by line for comparison last night ...
So this mod apply only for pre-LCI w/ the newer LM2 which will make the AE as DRL instead of the high beam:
Code:
1. TAGFAHRLICHT_ECE -> aktiv
2. VERHALTEN_DRL_TFL_33 -> drl_s
3. DRL_TFL_SML_33 -> aktiv
for #1 I think if you have DRL on/off menu in iDrive that function is the same thing.
for #2 default drl_h which mean high beam so no idea what drl_s mean?
for #3 make AE as the DRL.
As far as brightness I'm not so sure since I saw somewhere that PWM_FL_FKT_DRL_33 as a possible function.
GL!
Originally Posted by Ehssan
Update : drl_s doesn't do anything , so I'm stick to my method ,, I'm just waiting for my replacement kit of Orion V2 so that I can go a head and complete the project ..
Old 03-03-2011, 02:33 PM
  #422
BLooD's Avatar
Code:
GL!
WOW! nice job, next mod on my list.
Old 03-03-2011, 02:58 PM
  #423
Ehssan's Avatar
My Ride: Many BMW's
Code:
GL!
I don't remember if I tried the DRL_TFL_SML_33 as same time with drl_s , will try it and get back to you ,,,
also there is a guy from another forum have managed ti retrofit the LCI talight with LM1 with only playing with the brake lights PWM values ,, I got his LMA trc file , once the car is back from the dealer i will test it and will update you guys ...
  #424
BlaSTiWi's Avatar
... now ... next on my list is to figure out how to make the rear light rod on when w/ the AE just like the real LCI. ...
Old 03-03-2011, 03:01 PM
  #425
BlaSTiWi's Avatar
Yeah I think I may have to play w/ PWM values to make the rear light rod on w/ the AE as DRL ... so far I end up w/ the tail rod on but the inside (the one next to the rear fog or I guess the middle bulb) brake light bulb stayed on
Old 03-03-2011, 03:06 PM
  #426
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Code:
GL!
Heh, going to throw a monkey wrench in here to mess up your understanding a little.
Assuming you have LM2, your read out of LMA file would be similar to a LCI vehicle with same option. So in actuality, in order to make the AE's as DRL, only 2) is required. drl_s does translate into angel eyes, I have personally confirmed this last Sunday with a LCI halogen vehicle. I am not sure what 1) is, but it sounds like that's the option to indicate whether DRL is an option in iDrive or not. As for 3), I believe that's enabling DRL for LM2. I have to check my notes at home.
In any case, I am definitively sure that drl_s only works on LM2, and does nothing for pre-LCI (LM1) people.
Old 03-03-2011, 03:15 PM
  #427
BlaSTiWi's Avatar
Yes in my '07 it already came w/ LM2 ...
the #1 is to turn on the AE if you have no menu in the iDrive is you do I don't think you need to do #1 (I got the on/off option in iDrive) and as for #3 you have other choices (like rear lights) for DRL and SML is the AE ... I think TFL = TAGFAHRLICHT, maybe ... so you need #3 since the pre-LCI was set at nicht_aktiv.
Old 03-03-2011, 03:39 PM
  #428
NoQuarter's Avatar
Engine: N54
Well done Rival. Just went I start to dispare that we won't get any more fun stuff out of the experimenting!
Old 03-03-2011, 05:24 PM
  #429
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Jim, be the pioneer and figure out the BFD stuff!
With all those entries, including the algorithm entries, it makes me believe that it's possible to have flashing brake lights as constant and not just emergency braking.
Old 03-03-2011, 11:32 PM
  #430
Ehssan's Avatar
My Ride: Many BMW's
i'm sure with nettodata we can do it , i just started reading/learning it , its not as easy as trc files but if we managed to deal with trc files then we can deal with others too
Quick Reply: Car Coding
