Car Coding
Old 01-25-2011, 01:32 PM
  #231
NoQuarter's Avatar
Engine: N54
Originally Posted by andy545
trying to decode all my modules, anyone know the blank ones and confirm the "?" ones
One of the NCS scripts does a read of all the modules and spells out the full name of it. I would have to have it in front of me to find it but It is in there.
Old 01-26-2011, 12:10 AM
  #232
BLooD's Avatar
CAPPL, CCC-applications
CAUDI, CCC-audio controller
CGATE, CCC-gateway/MOST
CHOST, CCC-host
TMBT, Door module
TMFT, Door module
DWAI, Infra red detector for alarm system
DWAS, Anti-theft alarm system
MULF, Basic bluetooth handsfree system
Old 01-26-2011, 01:02 AM
  #233
Ehssan's Avatar
My Ride: Many BMW's
so what is TCUM module ??
Old 01-26-2011, 01:03 AM
  #234
BLooD's Avatar
Theres a TCUM which is the bluetooth and telematics module.
Old 01-26-2011, 05:57 AM
  #235
andy545's Avatar
Model Year: 2005
Engine: 545i
Updated (thanks Blood) - still missing a few...
ALC = adaptive headlight control unit
AMPT = hifi amp logic7
BFS =
CAPPL= CCC aplications
CAS = car access system
CAUDI= CCC audio controller
CGATE CCC gateway/MOST
CHOST= CCC host
CID = central information display
CTUM = Telematics?
DSC = dynamic stability control
DWAI = infared detector for alarm system
DWAS = anti theft alarm system?
EGS = electronic transmission control
FAS =
HUD = heads up display
IHKA = intergrated automatic heating and airco
KBM = body, basic module
KOMBI= instrument cluster
LMA = light module
LSMC = steering column memory?
MPM = micro-power module
MSHD =
MULF = basic bluetooth handsfree system
PDC = parking distance control
RLS = rain-light sensor
RSMC =
SBSL = b-pillar satellite left
SBSR = b-pillar satellite right
SFZ = vehicule centre satellite
SGM = safety and gateway module
SZL = steering column switch cluster
SZM = centre console switch cluster
TMBT = door module (front or rear)
TMFT = door module (front or rear)
will take a look at NCS and look for that script
Old 01-26-2011, 06:50 AM
  #236
Matrix76's Avatar
Originally Posted by miguex
I wish DRL_V_GEDIMMT had an additional "wert_x" specially for AE.
there are only 3 values (nicht_aktiv = none, wert_01 = indicators & wert_02* = beams *is default for Canadian version)
I believe there is theoretically possible to add AE as DRL on pre-lci. We need to figure out how to add a new value or find a hidden command that links to activate AE. If you put lights to position 1 you have AE on... why not to position 0 that is usually DRL. Only BMW engineers know how and they don't want to share...
I was told that in a German forum, they successfully did on an e65 with AE as DRL.
I actually found that TAGFAHRLICHT_ECE_1 nicht_aktiv in CAS/NFRM disabled the high beams CDN model. There were also 2&3 but had no effect when coded out. This might turn out to one of the more difficult codes to set.
Old 01-26-2011, 11:44 AM
  #237
Ehssan's Avatar
My Ride: Many BMW's
BFS =
CHOST= CCC host
TCUM = Bluetooth
FAS =
LMA = light module
MSHD =
RSMC =
in my car , I have TCUM not MULF . and i couldn't find the option to change the ringtone ...
Old 01-26-2011, 11:46 AM
  #238
Ehssan's Avatar
My Ride: Many BMW's
BTW , when I try to read the DWAS i get this error ,, any idea what could be the reason ??
Old 01-26-2011, 11:58 AM
  #239
bruce_miranda's Avatar
I've had problems with
BFS
DWAS
FAS
RLS
haven't tried recently with my updated set-up.
Old 01-26-2011, 01:09 PM
  #240
Ehssan's Avatar
My Ride: Many BMW's
guys , I've noticed something now ,, before I activate flash to pass bixenon option , my high beam used to stay like 1 second when I hit the high beam stick , 1 second is too much ,, and ppl gets angry considering it bad attitude .. after i activate the flash to pass bixenon in LMA , now even my bixenon stays for 1 second , so it's not flash anymore ...
tried to look at the LMA trc file maybe i find something in it ,, but i didn't understand it . for sure it's an option with different values not something like not active/active ...
guys with LCI headlights or guys with 2006/2005 ,,, if you don't have this issue with your high beam ... could you please post me your lma trc file so that I can compare it with mine and see if i can find that option to reduce the time of high beam ... because I remember in my previous 2006( 11/05 ) didn't have this problem ,, the high beam was really fast and it last for less than 1/2 second ... also in my E92 335I is the same ..the bixenon flash is really quick ....
thanks
Quick Reply: Car Coding
