Car Coding
Old 01-23-2011, 02:39 PM
  #221
miguex's Avatar
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
Originally Posted by neoe60
Video input function would be cool. I have HDMI output on my Android phone and it would be sweet to be able to see the Google Nav App in the car's main display.
I'm not sure what those terms mean, I'm going to have to find some beginner/noob posts about coding. I'm sure I'll refer back to this once I get a better understanding of the foundation of all this coding stuff!
Here is the list of FA:
http://www.bimmerfest.com/forums/sho...05&postcount=1
Sample $610 is S610A it means Head Up Display is installed.
Old 01-23-2011, 09:31 PM
  #222
Ehssan's Avatar
My Ride: Many BMW's
Originally Posted by andy545
Excellent. Looks like I've got some installing ahead of me...
hang on - I just realised you have prelci headlights with LM2 - right ? then you won't have the right setup for DRL and cornering light like NoQuarter mentions.
Yes exactly ,, the cornering is not as good as in the LCI headlights as you said guys , but at least it does something other than just being a high beam ,
welcome lights works perfectly ,, I have now the eyebrow - angel eyes - rear fog light and the number plate on , I will play with the other WL options to cancel the fog light - number plate and have the LCI tailight bars on ,,, great stuff guys ,,, appreciate your continues support ...
Old 01-24-2011, 10:37 AM
  #223
neoe60's Avatar
http://www.bimmerfes...505&postcount=1
Cool, thanks Miguex! What OS will the software run on? I have Win7 64bit, but heard that it won't run on that.
Old 01-24-2011, 10:45 AM
  #224
miguex's Avatar
Win XP Sp 3 32 bits
win 7 64 bits won't work but 32 bits yes.
maybe you need to reinstall the OS to XP or Win7 32.
Old 01-24-2011, 06:47 PM
  #225
Matrix76's Avatar
Can you explain to me exactly how you were able to get your angel eyes as DRL, been difficult sorting this one out, thanx Matrix
Old 01-24-2011, 11:48 PM
  #226
Ehssan's Avatar
My Ride: Many BMW's
Actually I have them as welcome light dude ,, for the preLCI we can't have angel eyes as drl as the other guys said ,,
but I was thinking if I can have the front indicators as DRL like US version , then we can manually link the angel eyes to it with a little wiring job .. , will have to look at it soon ..
Old 01-25-2011, 06:51 AM
  #227
Matrix76's Avatar
You mean with one of these, , http://www.jlevistreetwerks.com/p590...duct_info.html
Old 01-25-2011, 07:41 AM
  #228
miguex's Avatar
I wish DRL_V_GEDIMMT had an additional "wert_x" specially for AE.
there are only 3 values (nicht_aktiv = none, wert_01 = indicators & wert_02* = beams *is default for Canadian version)
I believe there is theoretically possible to add AE as DRL on pre-lci. We need to figure out how to add a new value or find a hidden command that links to activate AE. If you put lights to position 1 you have AE on... why not to position 0 that is usually DRL. Only BMW engineers know how and they don't want to share...
I was told that in a German forum, they successfully did on an e65 with AE as DRL.
Old 01-25-2011, 08:13 AM
  #229
Matrix76's Avatar
I personally have an 09 LCI, I hope that this issue can be solved for both the pre-LCI and the LCI models.
Old 01-25-2011, 12:28 PM
  #230
andy545's Avatar
Model Year: 2005
Engine: 545i
trying to decode all my modules, anyone know the blank ones and confirm the "?" ones
ALC = adaptive headlight control unit
AMPT = hifi amp logic7
BFS =
CAPPL=
CAS = car access system
CAUDI=
CGATE
CHOST=
CID = central information display
CTUM =
DSC = dynamic stability control
DWAI = anti theft alarm system?
DWAS = anti theft alarm system?
EGS = electronic transmission control
FAS =
HUD = heads up display
IHKA = intergrated automatic heating and airco
KBM = body, basic module
KOMBI= instrument cluster
LMA = light module
LSMC = steering column memory?
MPM = micro-power module
MSHD =
MULF = multi function steering wheel?
PDC = parking distance control
RLS = rain-light sensor
RSMC =
SBSL = b-pillar satellite left
SBSR = b-pillar satellite right
SFZ = vehicule centre satellite
SGM = safety and gateway module
SZL = steering column switch cluster
SZM = centre console switch cluster
TMBT = door module?
TMFT = door module?
Quick Reply: Car Coding
