Car Coding
#211
Model Year: 2005
Engine: 545i
luckily I have LM2
, I spent the whole day playing with NCS , I had almost everything , I'm not sure why welcome light doesn't work .. but in the trc file there is a lot of options for the welcome light ,,, guys who had the welcome light works ,, what exactly did u do ?
cornering light is so funny , it turns the high beam on when turning left or right
any idea which option to play with to have my angel eyes on as DRL ,, cuz i'm going with the orion V2 and I would love to have them on all the time ,, I see a lot of options with DRL in the LMA trc file ,, but donno which and what for ..![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Blood : let me know if you found the 2.8V , I tried yesterday to find it online ,, with no luck![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
I still can't get my cornerlights to function...maybe we can compare trace files?
for welcome you need the activation both in LMA and CAPPL plus have your light switch in AUTO.
This is what's active in my (LM2) LMA trace file with regard to welcome lights:
DEF_WELCOMELIGHT_CKM
aktiv
UNP_WELCOMELIGHT_CKM
aktiv
WELCOMELIGHT_CKM_0
aktiv
WELCOMELIGHT_CKM_1
aktiv
WELCOMELIGHT_CKM_2
aktiv
WELCOMELIGHT_CKM_3
aktiv
WELCOME_LIGHT_ACTIVE
aktiv
WL_AL
nicht_aktiv
WL_BLK_H
nicht_aktiv
WL_BLK_V
nicht_aktiv
WL_DAUER
wert_01
WL_FL
nicht_aktiv
WL_KZL
soft_einschalten
WL_MAX_DAUER
wert_01
WL_NSL
soft_einschalten
WL_NSW
nicht_aktiv
WL_POL
aktiv
WL_SL_1
soft_einschalten
WL_SL_2
hart_einschalten
WL_MIT_FLC
nicht_aktiv
WL_ZYKLEN
wert_01
WL_BL
nicht_aktiv
WL_SM
soft_einschalten
#212
I use DIS v57 for proper diagnostics when I need to check some thing, it`s quite amusing going in to the service centre already armed with the error info, I use my ODB d-can cable with DIS and Progman.
#213
My Ride: Many BMW's
aktiv
aktiv
WELCOMELIGHT_CKM_0
aktiv
WELCOMELIGHT_CKM_1
aktiv
WELCOMELIGHT_CKM_2
aktiv
WELCOMELIGHT_CKM_3
aktiv
aktiv
WL_AL
nicht_aktiv
WL_BLK_H
nicht_aktiv
WL_BLK_V
nicht_aktiv
WL_DAUER
wert_01
WL_FL
nicht_aktiv
WL_KZL
soft_einschalten
WL_MAX_DAUER
wert_01
WL_NSL
soft_einschalten
WL_NSW
nicht_aktiv
WL_POL
aktiv
WL_SL_1
soft_einschalten
WL_SL_2
hart_einschalten
WL_MIT_FLC
nicht_aktiv
WL_ZYKLEN
wert_01
WL_BL
nicht_aktiv
WL_SM
soft_einschalten
loool ,, I've done the CAPPL but in the LMA i activated only one option
#214
Engine: N54
luckily I have LM2
- The cornering light is kinda goofy in the '07. In the '08 version, that inner halogen is directed to the side to actually provide light where it belongs. When it is really dark, like out of city lights, the cornering light is pretty handy.
#215
Model Year: 2005
Engine: 545i
,, actually I followed the instructions from the other guys ,, will try it now ,, attached is my LMA trc file ,, the funny part is when I activated flash to pass option for the bixenon ,, the high beam is completely stopped working , even if my headlights are off , when I hit the high beam stick , my bixenon comes on ,, and the high beam yellow bulbs comes on only when cornering ...
![Doh](https://5series.net/forums/images/smilies/imported/doh.gif)
#216
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
Ok, I have 2 FSW_PSW.TRC (Full and LMA)
In the full one, I can see Welcome_Light_Active while LMA one does not show it.
Is there a way to see and change it? is it on another module? or need to add a VO?
Full (all modules: FSW_PSW.TRC.Full.txt
LMA module: FSW_PSW.TRC.lma.txt
#217
OK
On Topic \\
I propose that we create a database of the FSW_PSW.TRC.---- (--- is extension of the modul) files that have been read out and backed up and the altered files that are uploaded to, so we can compare and/or troubleshoot.
In the files themeselfs is no privat data stored, not even your VIN / Chassis Nr. The only info you can gather is the type of motor and type of bodywork (limo or break) and of course al the options installed.
Interested?
On Topic \\
Interested?
Create a Google Code project page: http://code.google.com/hosting/createProject
#218
What OS will support these programs? My laptop came with Windows 7 64bit. I'll probably do a dual boot, just so I can start coding, but what OS should I downgrade to?
Also, just got done reading the entire thread and didn't see this asked, is it possible to code in a cd changer input for the radio? I've been wanting to add an AUX input for my MY2006 non-Nav car, but they all require CDC to be pre-programmed in.
#219
If you see your FA.TRC file under /WORK
It will tell you what VO codes are on your car:
Mine is:
$1CA$216$261$302$319$322$403$415$416$423$430$431$4 41$442$453$459$465$473$
494$496$4MA$4MF$502$508$522$524$534$540$548$563$60 9$610$620$639$645$672$
677$693$697$737$754$785$818$838$845$850$853$876$89 6$925$992$999-A090
I want to add TV function (VO $601) and see it works or not.
Mine is:
#220
Mine is:
Mine is:
I'm not sure what those terms mean, I'm going to have to find some beginner/noob posts about coding. I'm sure I'll refer back to this once I get a better understanding of the foundation of all this coding stuff!
