Car Coding
#171
bhavi_jp, wish I can provide some insights but just got familiar with the coding only a few days ago. I'm sure you checked but just in case, make sure when you read the module, the *.Man file has to be empty in the work folder. Or else it will throw an error similar to that. Another time, I reread the module and then it programed fine after I had an error during the execution of the programming earlier.
#172
#173
May I ask which daten files do you have?
#175
Maybe the ncs version already has latest daten v.39 since who knows if it got thrown in.
But I strongly believe you may be missing the "CICR.PRG" in your C:\EDIABAS\ECU folder.
#176
Engine: N54
Try doing a a read of the index - I don't rememeber exactly what it says in German but it should be pretty easy for you to figure it out. Read the index - read the module - modify the .man file - code the the module.
#177
Hy to all,i am new to this forum,and i am asking to your help .I have inpa v4.4.7 ncsexpert 3.0.8 and somethimes i see on information an erorr "INTERFACE PROBLEM" and i have been closing the program,then it was ok but only for some thime ,and after a while same erorr.My interface is an vag com modified cable!
P.S. Can someone gibe me new daten file for a e60.
#178
I got my audio working by changing the AUDIO_SYSTEM_CIC to top_hifi.
I also changed some other options to us specific (since the module looks like it came from europe).
There is one thing I can not figure out. The mute/volume knob on CIC and the eject button are still not working. Is this a mechanical issue or is there a parameter I need to change to make those working? I am attaching the CIC trace file here.
Thanks,
Bhavi
#179
Big Thanks Key for your help. I can now code the CIC. It's time to go more into detail now.
Thanks,
Bhavi
Thanks,
Bhavi
TYPE_OF_FUEL
diesel_und_harnstoff
To petrol.
#180
