Car Coding
Old 12-12-2010, 08:33 AM
  #111
NoQuarter's Avatar
Engine: N54
So where are the settings BLooD shows in his menu screenshots?
Adaptive headlight settings,
High beam assist on/off,
Auto light control
I just tried to enable the fan speed settings in the climate control. I can't tell any difference yet.
Old 12-12-2010, 08:35 AM
  #112
NoQuarter's Avatar
Engine: N54
Originally Posted by Sas
Did you check to see if the file was reverted to original?
I did another read and sure enough it wasn't set back. I did it again, made sure it took the change and I got it back working as original.
Old 12-12-2010, 09:39 AM
  #113
NoQuarter's Avatar
Engine: N54
Auto light control
Also - what module has the options for closing windows via the FOB? I have seen a couple DIYs for it but I don't have the GM5 module that was referred to.
Old 12-12-2010, 10:25 AM
  #114
BLooD's Avatar
Congrats noquarter , if you are referring to comfort mirror folding from the fob, it`s in the KGM module from sept 2005 and it is called :-
BEIKLAPPEN_B_KOMFORTSHL.
The other menu options are in CAPPL, Look for functions begining with "VA", I think "VA" means vehicle access or some thing in german lol.
Sorry didn`t read your post correctly, check in the KGM and KBM modules.
Old 12-12-2010, 12:42 PM
  #115
Sas
Sas's Avatar
My Ride: 520i ('04)
+1
One of the first things i've tried to activate, oil level to but no luck. Had been cool to have a spinning fan and rpm's.
Old 12-12-2010, 01:03 PM
  #116
mandrsn1's Avatar
My Ride: 2004 545i
NCSExpert is a lot of fun to fool around with.
Still working to try and enable the Dension Bluetooth module.
The weather is too awful in Chicago today for more programming.
Old 12-12-2010, 01:34 PM
  #117
Sas
Sas's Avatar
My Ride: 520i ('04)
The Dension's BT is operated trough the Dension 500 menu: CD - CD1 - ROOT - BT - page 1 to 3.
Old 12-13-2010, 06:29 AM
  #118
mandrsn1's Avatar
My Ride: 2004 545i
I have it working for A2DP and streaming audio. It should also be able to emulate the factory bluetooth module and show up under the "Phone" menu on iDrive as well. That is what I am trying to do.
Old 12-14-2010, 10:55 AM
  #119
///MrSingh's Avatar
My Ride: 2007 E60 535d M Sport
Just attempted my first code, and I got the Digital Speedo working on the instrument cluster!
However, I tried to read the LMA and I get this error
I've attached a copy of the error log file as a .txt file
error.txt
Old 12-14-2010, 10:59 AM
  #120
NoQuarter's Avatar
Engine: N54
Congrats! As I just recently learned myself, you can expect the occasional error like that. Just keep trying or shutdown and start at the beginning. I think others will say it has to do with such and such cable, cheap this, ebay that, and so on.
Quick Reply: Car Coding
