BYPASS E60 PASSENGER SEAT SENSOR MAT
Old 04-10-2012, 04:04 PM
  #41
Shlooky's Avatar
My Ride: 545i
What kind of seats do you have? I have the problem with comfort seats and apparently the whole bottom part has to be changed, cost...$2,800!!
I'm not giving up though, will find the cause one way or another, thanks for the pics!
Old 04-12-2012, 02:36 PM
  #42
schranzkt's Avatar
I don't have comfort seats. ugh this is frustrating I cant figure out if this F-ing box thing is the mat sensor.
HELP
Old 04-14-2012, 12:25 PM
  #43
nyceric03's Avatar
My Ride: Black/BlacK
HELP
In your second pic you see the "plug" with the white, red and brown wire? Thats the head that you'd have to cut off and solder onto the emulator box and plug back in (the remaining dangling wires are fine to just leave dangling)
Old 04-14-2012, 12:35 PM
  #44
nyceric03's Avatar
https://5series.net/forums/topic/118...3#entry1391653
My post about what to do..
Here I made a picture to explain even clearer
http://i41.tinypic.com/wat54h.jpg
Old 04-14-2012, 12:37 PM
  #45
nyceric03's Avatar
Also it doesnt matter what seats you have cause all the emulator does is to force the signal that the seat is occupied. that will stop the broken seat mat error. However you may have to clear the error code. additonally it may bring up a seat belt unbuckled warning but in my original thread i listed a workaround of how to do it or you can simply click the seatbelt into the empty seat
Old 11-06-2015, 03:04 PM
  #46
Rushin5's Avatar
Originally Posted by papu84
Hello. I have managed to get my airbag light off with the following procedure. Follow that 3 whires and you will see that they go unther the leder of the seat. Get the leder off the clamps and you will find the SBE unit. The unit has a grey cable and on the other side it-s linked with the seat mat. Cut the 4 plastic whires that come from the seat mat, and solder 2 150 ohms resistors like in the picture atached. It worked for me. You may have to reset the airbag light. Tell me if it worked for you. (you will have to use a cutter to cut the silicone so you can solder the resistors. Easy job. Good luck !Attachment 123422
Sorry, your photo is blurry. Any chance anyone can repost the pic?
Old 04-26-2016, 03:12 AM
  #47
DanielFD's Avatar
My Ride: 2007 BMW 550i
Yes yes i resurrected an old thread, but because this thread was pretty useful, and i think somebody might find what i did useful. i had the Airbag light on and finally took shipment of my ICOM and used NCSExpert to code out the OC3 mat, but what wasn't mentioned in a bunch of threads is that on the comfort seats the connector for the mat is sometimes hidden under the leather backing right under the seat. Basically i just coded the OC3 mat to inactive then unplugged the mat but here is where i couldn't find anything online, it seemed i couldn't get rid of the error at all. I had a problem using ISTA where it wouldn't activate (turned out date was wrong) so i was trying to use my carly adapter/app to clear codes and it would say successful but wouldn't clear the code (thought that i had coded incorrectly). Eventually (the next day) I fixed ISTA (set the date) and cleared the code. Problem solved.
Old 11-06-2018, 11:12 PM
  #48
Baliboy's Avatar
My Ride: 2005 e60 5 series 2300cc saloon
Hi
I live in Bali Indonesia and i had the airbag fault i installed an emulator on the passenger seat and rest the error with INPA the error on my INPA screen but i could not reset the Idrive and when i switched the ignition off and back on the error reappeared can someone explain f i am doing something wrong as it is driving me up the wall
Old 01-22-2024, 02:59 AM
  #49
Bmw e61's Avatar
My Ride: Bmw e61
Hey! I have the Airbag light and seat belt light on in my car. I read the codes on the car and the code was 9913. I found instructions on the internet how to trick the sensor with a resistor and a diode. We were advised to use 1n4001 diode, but the seller said that 1n4007 does the same thing. So i used a 1n007 diode and a 200ohm resistor as advised online. Code 9913 went away, but was replaced by code 9914. Can someone help where that code comes from? My guess is that the resistor might be the wrong size or something because that code didn't exist before.
kajin99
03-26-2014 08:24 PM
bimmerdude1
03-06-2012 09:48 AM
r9ndy
05-28-2011 06:30 PM
shebuilt
01-10-2011 04:07 PM
disnikhavikta
DIY: Do It Yourself
06-30-2006 01:32 PM
Quick Reply: BYPASS E60 PASSENGER SEAT SENSOR MAT
