Brake Pad and Disc replacement
Old Oct 3, 2010 | 12:20 AM
Steve J's Avatar
I tried the search function but couldn't find what I was after.
Q1. Where on earth is the brake fluid reservoire on a 535d? I can't find it anywhere in the engine bay. Usually plastic reservoire with screw top and sensor but I must be going blind, but I can't see anything like that.
Q2. What's the minimum thickness of the discs? Mines at 34mm on the front.
Cheers
Old Oct 3, 2010 | 08:26 AM
healthservices's Avatar
You have to do a search "brake fluid change"
http://forums.5serie...h&fromMainBar=1
Cheers
It is stamped on the rotor.
Old Oct 3, 2010 | 08:57 AM
BlaSTiWi's Avatar
Wait? What? Is the brake disc thickness = tire pressure ???
[size="3"]
Old Oct 3, 2010 | 12:51 PM
Steve J's Avatar
Even using "brake fluid change" had to trawl through loads of threads to find the right one. Eventually got it, thanks. That's why I couldn't find it, hiding it underneath the cabin filter, the crafty buggers.
I assume it's stamped on the bell part of the rotor (too wet to check today) otherwise if it's on the edge it will have rusted off. lol
Cheers
Old Oct 4, 2010 | 07:41 PM
Search function is not the greatest but if you know how to do a search it gets easier.
Use quotes " " if you think the words maybe used together in a sentence.
The more search words the better.
Search just the forum you think it may be in.
I only found '9' results using my method.
The first three threads had the answer you wanted in it.
Give a man a fish and he will eat for a day. Teach a man to fish...
Of course if everyone just knew how to use the search function this forum would have been dead years ago.
Old Oct 4, 2010 | 07:44 PM
On the Rotor, not the tire.
Old Oct 14, 2010 | 07:01 PM
z06bigbird's Avatar
Rotor thickness, tire pressure, sperm count, obscene gesture, IQ, etc. Aren't they all the same!!
RobR
Jun 2, 2015 08:31 AM
Yas1083
May 12, 2015 12:46 PM
TexaZ3
May 6, 2015 09:54 AM
Sakru
Mar 26, 2015 09:26 AM
