Brake fluid change DIY
#94
My Ride: 530i
Engine: N52
Great write up.
The whole trick to bleeding brakes is patience.
Just make sure when you are done the pedal is as hard as a rock or you'll experience the effects of air in the system.
I generally don't use pressure systems.
I first vacuum out the master cylinder with my air powered bleeder assem. Then I fill with new fluid. This gets out any bad effects from the resevoir and prevents them from traveling in the system during the process.
Takes more of the old fluid out faster and makes the process easier.
I then regularly fill the M/C as I bleed each caliper.
I have my bride pump the pedal so I am sure I have bled out everything on each caliper.
Either way is fine though.
#95
Bavauto says I need a $20+ adapter for a 2005 545... from the pictures it looks like I should be ok with the stock twist one.. anyone tried this?
This adapter allows you to use your Bavarian Autosport Brake Bleeder on autos other than BMWs. Works on reservoirs with filler openings up to 90 mm in diameter. Has quick connect fitting for use with PB03 brake bleeder. Part Number Description Price Qty. ALB30583 Multi - Vehicle Adapter for Bavarian Autosport Brake Bleeder
part : ALB30583 (which does state that this is for cars other than BMW...)
#96
Skip BavAuto and buy the Motive brand. Motive is the OEM for BavAuto.
Search Amazon for ASIN B0002KM5L0
It will cost $50 delivered to your door.
#97
Amazon.com: Motive Products Power Bleeder Adapters to fit most European car models: Automotive
I forgot to refill the master and just attached the bleeder with two Qts of new fluid after I sucked out the old fluid, also forgot to pre pressurize it and just pumped it to 20lbs and bled all 4 calipers and still had a qrt in the bleeder when finished, pedal hard as a rock....
#98
That's what I have used twice now, works like a charm, also for,those wondering about getting air in the system with this unit it does not!!
pinguhk
15
08-19-2008 06:32 AM
