BMW E60 Steering angle sensor. DIY Cleaning/ Replacement
Old May 18, 2023 | 10:24 AM
KKDriver's Avatar
My Ride: BMW x5 2012
Model Year: 2012
Engine: Diesel and Petrol
Default BMW E60 Steering angle sensor. DIY Cleaning/ Replacement
If you get dashboard error on your BMW e60 with the Steering sensor alarm and DSC / ABS OFF you most probably need to clean the steering angle sensor disk.
BMW E60 Steering angle sensor is hard to break and if any malfunction occurs most probably you need to clean it.
The video below is showing you How.
Old May 18, 2023 | 11:41 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
I've replaced my SAS 3 times so to me cleaning is a long shot. It also depends on which SAS you have. The one in your video is a newer version. The older ones will always need replacing due to the pins on the disk breaking.
bens1088
May 30, 2013 10:07 PM
Won550
Aug 8, 2012 06:34 AM
PKELLEY
Aug 26, 2011 09:54 AM
torogi
Dec 8, 2010 07:18 PM
monnot66
Nov 2, 2009 04:06 AM
