Battery Replacement
Old 01-09-2009, 08:14 AM
  #21
salaki's Avatar
My Ride: 05 545i 6MT
Thanks for the block of wood information
I will keep that in mind when I need to replace my battery.
Right now, I'm using Battery Tender to make sure that my "German" battery will last me a while.
Old 01-16-2009, 05:29 PM
  #22
evo42's Avatar
My wife was driving the car today while it threw every code in the book at her. I had her pull over on a side street to stop/restart but it wouldnt start. No sound.
I had it towed to the local dealer, they can't look at it until next Thursday due to current load. I'm gonna buy a battery in the mean time to see if fixes the issue.
Anyone know what tools are required to remove panel and battery so I can show up prepared?
Old 01-16-2009, 05:47 PM
  #23
JAY'545's Avatar
Anyone know what tools are required to remove panel and battery so I can show up prepared? To remove the panel,no tools are needed. Just turn the tab halfway. Tools for the battery are your basic hand tools.
Old 01-16-2009, 06:33 PM
  #24
RatherBeInCabo's Avatar
You need a slotted screwdriver to remove the panel and then I think you need a 10, 11, 13 and one other metric socket. Very basic tools. Oh and a phillips screwdriver for the clamp that holds the battery in place.
Old 01-17-2009, 02:37 AM
  #25
sixcard's Avatar
My Ride: 08 550 Carbon Sport Almost everything factory, but no sound upgrades.
Originally Posted by RatherBeInCabo' post='763005' date='Jan 8 2009, 04:54 PM
Yes, when you totally lose power, Active Steering needs to be reset. The battery did not cause the error, disconnecting the battery causes the reset. It is described in the manual. The car was not able to start with the old battery. I never received any kind of warning that the battery was low or weak prior to the failure at the car wash. Just so happens there was a brand new M3 Vert next to me. It was quite embarrassing when the car had to be pushed out of the line.
Marc
Great info and presentation Marc!
I have had similar problems but at an earlier stage, of battery life, than you.
I think (speculate) that the system shuts down ?lower priority? functions (e.g., AS) first so as to not prevent starting the engine.
In my case(s) the AS would be disabled and instrument cluster saved data was zeroed but the engine did start. After a few hundred yards of driving the AS would initialize but I had to manually reset the time and date and the trip odo, elapsed mpg restarted at zero.
After much go around with the dealer I ended up with a ?trickle charger? that I will have to use on occasion. Though called a trickle charger it will monitor the charge and shut down at full charge.
BTW, my OEM battery is 110 AH.
My 550 is 18 months old an has approximately 20,000 miles.
Many thanks for your input.
sixcard
Old 01-17-2009, 08:45 AM
  #26
xxrap985xx's Avatar
My Ride: 2005 545i Cold Weather Package Navigation and Logic7 Package Sport Suspension Package
Originally Posted by advancedlogic' post='762887' date='Jan 8 2009, 02:33 PM
Thanks for the write-up! The battery containes no identifying electronics, so whomever came up with the idea of 'registering the battery with the car' was mistaken. However, it is extremely important that the replacement battery is of similar specs to stock, due to the sensitivity of E60 electronics.
my battery is going bad and iwas wondering could i replace it with a optima red top battery?
Old 01-17-2009, 09:06 AM
  #27
skylolow's Avatar
As far as I know no Optima battery is approved for your BMW. I won't risk it with how electronically fussy these cars can be.
Old 01-17-2009, 06:46 PM
  #28
evo42's Avatar
I put the recommended werker battery (SLIP5R-LI) in the car today, it started right up. I did the active-steering reset and then shut the car off. On startup, the alert wasnt there but I had a CEL with the increased emmisions message. I drove it home, but half way I got an alert on the driving system (car may not handle correctly, slow down in turns) so I shut it off, then started it. The CEL and the new alert were gone. Hmmmm.
Hopefully screen remains alert free, so far so good. Thanks for the info and help.
Old 01-18-2009, 10:21 AM
  #29
1esquire's Avatar
My Ride: 2009 DINAN 135 convertible
Hi guys, long time no post. I moved, new job, not as much time to surf, etc. Oh, and those carbon-fiber "style" grills that I got finally started turning yellow and peeling, so I guess they weren't that great after all (although I got my $24,95 out of them).
Anyway, I have been having the same problems discussed above: steering malfunction light, active steering light, usually only in the mornings on start up when the weather is near 0. My battery is still original, so going on 5 years old. When I start it in the AM, in turns over slowly and then starts. I am thinking maybe I just need to change the battery.
Can anyone confirm what has been said on here about the active steering failure being related to a low battery? Has anyone put in the 49DL battery from Autozone rather than the 95R, and if so, have you had any problems with it?
thanks guys.
Old 01-18-2009, 11:11 AM
  #30
evo42's Avatar
Originally Posted by evo42' post='770539' date='Jan 17 2009, 09:46 PM
I put the recommended werker battery (SLIP5R-LI) in the car today..
My bad - SLI95R-LI
Quick Reply: Battery Replacement
