Another oil change question
Just changed my oil on my '05 545i yesterday. Thanks to all the DIY posts on this forum for making it an easy job! I also had the issue of not being able to loosen the drain plug out of the filter housing. I believe i read some where to simply use a 24mm wrench to hold the filter housing in place while you loosen the drain plug. I only had a 24mm socket available, so I couldn't hold the housing and I didn't want to risk using an adjustable.
The car seems to be running MUCH more smoothly and feels like she even has a little more pull. Maybe it's just psychological?
My Ride: 2005 545i, Silber-grau/grau. Vanilla flavored except for cold WX pkg.
socale39
Sep 5, 2023 08:30 AM
mantraguy
Mar 9, 2015 02:56 AM
Don Juan
Mar 11, 2004 03:14 PM
