AE Illumination when unlocking the car
#181
#182
Engine: N54
#183
#184
My Ride: BMW 535xi
Would it not be easier to tap into the daytime running light at the headlight, rather than at the footwell module, eliminating the need to run any wires through the firewall? Didn't you get a "light out" indicator or reoccuring bulb failure from your procedure? Thanks.
#185
Hi Guys,
I have a quick question for the AE exports. Did any one experience a Check engine soon light coming on after this mod? I followed the wiring diagram and double checked all the parts to make sure it correct and it is. The AE illuminate as my DRL which is what I wanted however, the next morning when I was pulling out of the driveway, the Check engine soon light came on. I just wanted to find out if I'm the only one experiencing this. This is happening on my 2007 530i. I'm also going to get a OBD scan to see if it might be something else later today but just wanted to check here first.
Thanks,
Thanks,
#188
My Ride: 2006 BMW 550i
but then you wouldnt get the lights to turn on when you unlock your car....only when the car is started.
#190
hi,do you have picture of the wire? what colour is the wire? which wire should i tap?
Read my posts from way back. I have no footwell either, so I tapped it to my dome. The wiring is hidden away through the A pillar.
And on that note, I actually bought the parts to retrofit footwell and it arrived yesterday. I'll either spend today, tomorrow, or Saturday, and get it installed![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
