AC basic to AC high retrofit DIY rev.3
#71
#72
My Ride: BMW 525dA 2007 pre-LCI.
Interesting, sounds logic, the service interval of the micro filter is calculated by the use of the ventilation. And since the LCI module doesn't have this it doesn't give the info back back to the iDrive.
Going to switch it off of also, doesn't work anyway as it is impos to predict how dirty the air is.
#73
Blood one question, did you take the power of the AUC sensor from the IHKA module or direct from a fuse. Mine isn't working, I took the power from a fuse like on the LCI ?
#74
I took the power for the AUC from the IHKA, there is a problem I have yet to resolve with mine as well which is to do with the ventilation flaps. My IHKA is recording a fault code from the AUC saying the vent motor is not working.
#75
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
hi blood im changing my pre lci high heater panel to the Lci high heater panel do i need to change any wires on the blue plug? also is it coded under the same Sa number as the pre lci high panel
will i get this micro filter message if how do i disable it thanks
mine is a 2003 E60
mine is a 2003 E60
#76
mine is a 2003 E60
mine is a 2003 E60
#77
I take it the wires dont need swapping around then and vo order stays the same just reseting ecu
#78
#79
i checked out i need to mod the pin 21 for LCi climate control mod to the power wires on the control panel
does any one know what needs to be codded to remove the service micro filter error how to remove this?
thanks
thanks
