AC basic to AC high retrofit DIY re-write.
#85
now the weather is getting colder here in the uk ,i just found a problem (i think) with the heater setting after the retrofit .
found out that the centre vents dont blow out hot air only cold ,this also effects the rear vents that run through the centre console they only blow cold air as well .
no idea if this can be altered in the ihka coding or not, or wether its to do with how the panel is wired and cannot control the flow of water through the valve ,but as i dont understand german and online translators are poor i cant sort the problem.
#86
#87
My Ride: BMW E60 525d MT
In my car everything is ok after this retrofit. Both vents blow hot or cold while regulating the airflow temp from the i-drive, checked it today.
#88
bit of a late reply been quite busy , the temp for the centre vents in the idrive is set fully to warm , but heaters blow cold still from front centre vents and rear vents ,wouldnt mind so much except my year old daughter is normally in the back . also i believe that if its fitted then it should work correctly .
#89
