AC basic to AC high retrofit DIY re-write.
#41
Sorry for foulding this thread but I wanted to inform that the problem is solved.
Why can't I edit a previous post after one day
Okay.. this is what went wrong.
Almost all cables in the X18793 connector have a differrent colour.
Except nr 4 and 14 are grey-black and 11 and 15 are green-black
So I ended up mixing the 4 and 14 cables when rewiring to X1527.
In that way I exchanged the airco compressor relais with the rearwindowsheating :thumbsdown:
#42
Hi BLooD,
Just picked up an E61 this evening, to replace my E46, and was thinking about this mod even before I handed the cash over. Great post - thanks for posting it. Can I ask a simple ( and likely stupid) question though please.... Can this mod be done on cars with no nav system at all? and would the wiring/ parts list be any different?
#43
Hi BLooD,
#45
Hello guys i need help please i have the same problem after i finished the retrofit there its extra sound from the engine compartment after i start it looks like its the engine fan that its running on full speed only when i start the engine in rest all the AC control unit its working PERFECT !!!
What should i do i checked lots of times to see if i done something wrong but all the wires i put them the same like BLooD explain
PLEASE NEED HELP WHY ITS NOT WORKING !!!!
#47
You need to locate pin 21 of the blue plug and cute the wire leaving enough on both ends.
Take the bare wire in the loom and run it to the brown earth on the two pin plug.
Take the wire from pin 21 and run it to the red power feed on the two pin plug.
Set the following functions in CAPPL to "aktiv" :-
VA_AUTOMATIC_SHORTCUT
VA_AIRVENT_SHORTCUT
#49
WOW thanks a lot looks like its working i dont have that sound from the engine fan but i still need to do the coding i need to find somebody that can do that remotely coz i dont know how to do it
Anyway thanks a lot again you make my day !!!
#50
