535i subframe lowering
Old 12-30-2020, 08:47 PM
  #21
CaptainMorgan535i's Avatar
My Ride: E60 535i
Model Year: 2010
Engine: N54
Originally Posted by iShapeshifter
so...over a year later, the world has changed with the virus. But the car is still going strong! Hasn't been driven much this year, but have not had any issues related to this repair. wonder how @captainmorgan535i did with the oil leak...too much time on my hands the day before new years eve.
I ended up taking it to a small start up shop owned by someone who owns a n54. Around $700 in labor, and now I'm DIYing the mechatronics solenoids and sleeve after a successful water pump replacement. Cheers to a new year, hopefully a brighter one for all of us!
iShapeshifter (05-03-2022)
Old 01-13-2021, 04:52 AM
  #22
acarpenter's Avatar
My Ride: 525xi
Engine: n52
I’m going to be tackling a “job” today using this guide. 2008 535i replacing oil pan gasket and turbos due to failed waste gates. Wish me luck!
Old 01-13-2021, 05:28 AM
  #23
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2001 325i 5MT
Engine: N54, M54
Good luck! I did this a year and a half ago and tracked some of it here, maybe it can be helpful as well.
Old 01-13-2021, 02:28 PM
  #24
acarpenter's Avatar
My Ride: 525xi
Engine: n52
thanks!
yeah, I got a lot done today and I feel like I still have a ton to go.
any tips for these items?
-can’t really get to passenger engine Mount but due to inlet in the way.
-DP band nut is super hard to access and swivel socket doesn’t fit quite right.
-steering shaft won’t “pop off”. I’m assuming the rack has to be lowered for it to have room to do so?
I know I’ll get the turbos off tomorrow. Just going slow.
Old 05-03-2022, 12:52 PM
  #25
jae350gt's Avatar
My Ride: E60 535i
Just wanted to jump in here and say thank you for this post..i seriously think this is the one and only resource on dropping the subframe. I'd buy you a beer. I did have a bracket along the drive side with two t30's i had to take off to free the cooler lines. There was also a 10mm on a bracket in the center of the rack too...drop it slow so you don't miss anything. Cheers.
Old 05-30-2022, 04:19 PM
  #26
Probation Members
domni51's Avatar
My Ride: 2008 535I Stock
I literally (yes I mean literally) signed up to say thank you for the post. My 535I was sitting on block stands for a few months while I procrastinated because all of the other info I found on dropping a subframe (E90s and 528s) didn't quite fit what I was seeing on my car. I originally got the link from another forum you posted to in response to a member asking about dropping the frame on a 535I.
Old 10-27-2022, 03:08 PM
  #27
Probation Members
Hajo's Avatar
My Ride: 2004 BMW 530i, sport package, 6-speed manual, m54 inline six
Default 530i steering shaft help
thanks!
I'm currently doing the pan gasket on my 530i and having a similar issue with my steering shaft. Did you ever find a solution?
kd7iwp
DIY: Do It Yourself
12-27-2022 06:53 PM
calebcosentino
07-27-2017 07:58 AM
yakev724
DIY: Do It Yourself
11-24-2015 11:56 AM
E60I
DIY: Do It Yourself
08-15-2015 09:11 AM
Sam@sleekmotoring
7 Series Discussion
41
04-07-2009 09:21 PM
Quick Reply: 535i subframe lowering
