535i subframe lowering
I've got a 2008 535i sport that ingested the serpentine belt through the front crank seal, so I'm trying to remove the oil pan to clean out the pieces. I need to lower the subframe and I can't get to the passenger side engine mount bolts. Do you have to remove the exhaust down pipes to get to them? Also, there are two fluid lines that pass through the subframe. Do they need to be removed?
Ken 2008 535i Sport Package 6 speed manual |
Any Update on subframe lowering
I have the same car, need to lower subframe to replace turbo cooling lines. Any information on your journey would be appreciated.
I'll try to describe what I did.
1. Raise car and put on jack stands. 2. Remove front wheels 3. Remove engine cover 4. Install engine lift ring (same as tow ring) and engine support (I used the Harbor Freight version) to support engine (apply some pressure to lift the engine slightly) https://cimg8.ibsrv.net/gimg/5series...1d6d80e21b.jpg 5. Remove belly pans 6. Remove subframe stiffener plate 7. Remove steering column to steering rack pinch bolt and pull off steering rack 8. Disconnect electrical connector from steering rack 9. Siphon out power steering fluid from the power steering reservoir 10. Remove wheel well covers from around steering rack arms 11. Disconnect 4 hydraulic lines in passenger wheel well just behind the wheel (two shown in the photo) Note- these go to the active stabilization and power steering. If you don't have the sport package with active stabilization, then it may be different. https://cimg5.ibsrv.net/gimg/5series...586374c80b.jpg 12. Disconnect the hydraulic quick disconnect at the lower passenger side of the radiator. Remove the white clip and slide the QD sleeve away from the radiator to release. 13. Remove the top nut from the drivers side engine mount. 14. Disconnect the vacuum accumulators mounting bolts to gain access to the passenger side top engine mount nut. Use long extension and universal joint to reach the nut (may have to bend back the heat shield. Once you have the nut loosened, you can reach it by hand from underneath to remove it by hand. 15. Disconnect the end links from the active stabilization roll bar (this step may not be necessary) 17. Remove the link on the height sensor on the passenger wheel side 18. Place a floor jack underneath the subframe. I used a 2x6 to span across the subframe just behind the jack pad point. 19. Remove the 6 subframe bolts 20. Slowly lower the subframe. The subframe and engine mounts will lower away from the car and engine and remain connected to the lower and upper suspension components. Hard to really see, but here's a picture of the subframe lowered. https://cimg9.ibsrv.net/gimg/5series...282fad2c41.jpg Note that the subframe and stiffener bolts are torque to yield and BMW calls for them to be replaced. I put in new subframe bolts, but reused the stiffener bolts. I also replaced my engine mounts since I'm at 110K miles. Both were slightly collapsed when compared to a new one. https://cimg4.ibsrv.net/gimg/5series...550a2b878e.jpg Ken 2008 535i Sport w/6 speed |
I was doing this today for the same reason.Your post proved to be invaluable to me since I couldn't piece it together on my own with just whatever is available in TIS.
Many thanks to you, sir for taking time posting this! One thing I wanted to add, for automatic transmission you *absolutely* have to disconnect a mounting bracket which fastens trans cooling lines to the subframe. Yes, subframe, not oil pan. Bracket is located on the driver's side and is pretty much hidden unless you know what you're looking for. Here's a link to TIS online. It's a second to the last diagram: https://www.newtis.info/tisv2/a/en/e...l-sump/4NuSJRf Whoever worked on my car before my time didn't release that bracket when lowering subframe and that costed me a transmission since it ended up running low on fluid due to a slow leak thru that crack. Cheers! |
Originally Posted by dpersh
(Post 1600367)
Originally Posted by rkvarner43
(Post 1594333)
7. Remove steering column to steering rack pinch bolt and pull off steering rack ... |
Ken, your instructions became invaluable for me since I have the same car (2008 535i Sport Package 6-speed manual) and was doing oil pan gasket replacement. Quite an involved job and needed lowering the subframe, also replaced the engine mounts since I was there. For those taking on the oil pan gasket replacement - in addition to the steps above you need to release three E12 bolts on the power steering pump to get access to a couple of oil pan bolts. I also had to remove the plastic front intake charge air duct to get access to the T60 tensioner bolt in order to remove the serpentine belt from the power steering pump pulley.
11. Disconnect 4 hydraulic lines in passenger wheel well just behind the wheel (two shown in the photo) Note- these go to the active stabilization and power steering. If you don't have the sport package with active stabilization, then it may be different. I got everything together, added more than 1L of CHF-11s power steering fluid since most of it was flushed and the car drives again. Yet I'm getting "Steering malfunction: Possible hazard from fluid loss in steering or suspension hydraulic system" error right after turning on the ignition. Tried to reset the codes with the INPA but 5D60 fault code comes back immediately. Since the fault is "permanent" and comes as soon as the ignition is on then I hope it's something simple and I forgot to connect some switch, yet I'm scratching my head yet what I could have missed (finished assembling the car late last night - was pretty tired already). Ken, if you are reading this, did you do anything special after adding power steering fluid back into the system? |
Yay, my car is perfect again! Turns out something silly as I hoped - when I moved my power steering canister to the side to get better access to the engine mount nut somehow I got the power steering fluid level sensor plug disconnected. So if you are reading 5D60 fault code and "Steering malfunction" error on the dash then I think it should be the first thing to check.
This thread. Thank you for the postings. They were invaluable in doing a oil pan gasket as well as a leaking turbo coolant line. I did not want to have to disconnect all the suspension components. All the instructions were on point. Thanks @dpersh for the heads up on the bracket as I also have the automatic transmission. Removing the cats was pretty tough, used long extensions to get to the bracket bolts. The leaking coolant line was the rear turbo and super tough to get to it. putting in a bolt in a hole you cannot see took quite some time. I also did the motor mounts, water pump, thermostat, serpentine belt and pulleys. My oil pan had two broken bolts, I had to use a drill and an extractor, but they came out easily with the correct tool. Speaking of tools, I had to use just about every tool in my tool box, and had to be super creative and patient to get it all done. I had never gone this deep into the car before, so I took a long time to understand what and how everything went together. Car is all back together, no leaks and no warning lights. Sounds and works amazing and thanks to the forum as this was the only thread I found on a 535i with sports package. That active sway bar and its components make a big difference in how this job is undertaken.
Glad it was helpful. Really not too bad if you take your time. Hardest part for me was installing the engine mounts (took an extra set of hands to guide the mounts in place as the subframe was raised). My water pump had been previously replaced under warranty so I didn't replace it, otherwise I would have as it it MUCH easier to get to with the subframe lowered. I did replace the upper and lower radiator hoses and changed the coolant.
My next big project is to replace the shocks and struts, and possibly the front control arms. Starting to get some sway after 130k miles :) |
