Cant permanently rid my hood of oxidation?
My Ride: 2008 550i, alpine white with beige nasca ventillated leather, cold weather package, sport package, active steering, comfort access, rear power sunshade, land departure, navigation, heads up display, ipod adapter, satellite radio, pro logic sound, and rear side airbags.
My daughters 2002 jag has oxidation on the hood, that seemed to go away when I compounded the hood but it always reappears in a couple of days. Do any of you have any ideas of what I should use to get rid of this problem permanently? I used an over the counter product called rubbing compound with hand application and with a Porter-Cable 7424 6" Random-Orbit Polisher Buffer . It looks really good and then in a couple of days the discoloration is back.
Originally Posted by westcoast550' post='536422' date='Feb 26 2008, 04:32 PM
Did you seal it after cutting it ??
Beats me then , there are a few excellent detailers here ,someone will know !! Sorry I can't be of any help . Good Luck
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Are they FULLY cured before you buff off the sealant and did you wait the sealant to sit-in your paint before you apply the wax? and wht compound have you used?
Sounds wired...cos It should not re-appear if it sealed properly.
Sounds like you took the usual detailing steps to restore the finish on the Jag.
A while back some automotive finishes didn't hold up well over time and the damage was blamed on industrial fallout etc. In one case I recall Ford finally agreeing to issue a recall but don't remember the details.
If your paint wasn't damaged by aggressive rubbing compounds and the fault is with the paint itself you might try a warranty claim (under the corrosion coverage??? ). Even if the car itself is out of warranty in the interest of customer satisfaction Jag might agree to repainting a panel or the whole car .
My Ride: 2003 Audi RS6/2002 Porsche 911 Turbo/2007 Toyota FJ Cruiser
If its etched into the paint there isn't much you can do but wetsand or compound.
Originally Posted by pyiu' post='536480' date='Feb 27 2008, 01:38 AM
I would probably wash/clay the car, then use a strong compound maybe like Menzerna Power Gloss Compound and a more aggressive pad, I"m going to say either its etched into the clear or you didn't fully break down the compound.
ucsbwsr
09-19-2015 10:58 AM
Bank$hot530
09-16-2015 01:28 PM
umichchris
09-10-2015 12:54 PM
