Dealer Purchasing & Service Forum What's your dealers sales and service department like? Post finance and lease questions here too.
Rolling fenders or cutting
Old 04-13-2009, 10:20 AM
GQ530's Avatar
My Ride: 2005 BMW 530i
Originally Posted by lorinzo' post='832177' date='Mar 31 2009, 08:20 PM
Is there any specifics for "rolling fenders."
I have heard about this process but, am uncertain as to what it means exactly.
Does it involve bending of the metal fenders? Afterwards, is it visible from the exterior? Is there risk of paint damage? Warranty issues? Dealership issues?
When having the process done, do you request an amount of roll... meaning, do you roll an inch, two inches?
If the shop you take it to knows what they are doing then you shouldn't have to worry about your paint cracking, but then again, shit does happen sometimes. The shop I take all my cars to has a gizmo that attaches to the wheel hub with an adjustable arm and some kind of a roller on the end. They heat up the area to be rolled then go back and forth with the roller little by little with somebody following the arm with the heat gun to maintain the higher temperature so the paint doesn't crack. This whole process is basically bending the inner part of the fenders inward in order to provide more clearance. As I stated in the beginning, if the person performing this knows what they are doing, it should not be visible at all from the exterior; however, if the person doesn't know what they are doing, then you risk cracking your paint, getting ripples/dents on the outer fenders, and so on. Hope this helps.
Old 04-13-2009, 10:24 AM
dbae1978's Avatar
Roll the fenders.... go to Eurorev! they're a very reputable vendor on this forum.
You can call or pm member John@eurorev
good luck
Old 04-13-2009, 01:36 PM
flyingpuck's Avatar
Roll them first, you can ALWAY cut them later!!
FlowerBomb
11-03-2015 10:18 PM
EuropeanArtz
09-29-2015 04:26 PM
timmay77
09-24-2015 09:38 AM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
ucsbwsr
09-19-2015 10:58 AM
Quick Reply: Rolling fenders or cutting
