07 530xi maintenance and other issues
my 07 530xi has about 48.5k miles now and I had several questions that I hope any of you could possibly help me out with it. Thanks a lot for your help!!
1). Idrive shows that my rear brake will need to change within 3k miles, and i know the brake is cover under the bmw original maintenance program. Just wondering if dealer will willing to help me change the brake before it hits 50k.
2). I bought the car for about a year now and drove about 10k, however idrive never told me to change any oil. Just wondering if I need to change some oil for the car or dealer should change them for me.
3). I felt a slightly wheel vibration on 50-80 mph, do you guys know what might be the possible cause for this? Btw I did not modify any part of the car.
I hope your dealer will be willing to change your brakes for you before hit 50K.
You can change your oil once a year... its the low mileage annual oil change.
air pressure?
air pressure?
2. You are entitled to one oil change per year, regardless of mileage.
3. Balancing/pressure most likely the cause. Check your pressure level and if not, ask the dealer to road test it while you're there. My dealer only charges $22.00 per wheel road force balanced, so its not expensive.
Good luck.
chadillac2000
42
09-13-2017 11:15 AM
