USB, Ipod, Gateway 500, etc... HTC!
#31
On my old JAMin it works
Why on the Jamin does it work and doesn't work on the HTC ?
Maybe for the different windows... Mr. Igor V. Bozhko, we need a new version
Edit :
http://forum.xda-developers.com/archive/in...p/t-298056.html
So there are other utilities that do the same function ...
Edit2 :
http://www.softick.com/pocket-pc/cardexpor...amp;new_lang=en
I need this utility and it should work properly. I am beginning the research for it .
Edit :
Edit2 :
#32
Success!!!
CardExport311_en.doc
(change extension to .zip)
Install it and it will work!!!
For the Touch Cruise you need the version 3.08 or higher .
The last problem is finding a serial/crack, but I'm quite hopeful!
Edit :
Cracked version, without the entry 'Register' :
Softick_Card_Export_II_3.08_wm5_Cracked_SergeyL.doc
(change extension to .rar)
Well done Alex!
Edit :
Well done Alex!
bestofthebest
03-28-2016 02:47 PM
wooboodoo
10-25-2015 02:58 PM
Bank$hot530
09-16-2015 01:28 PM
