Bluetooth Phone Operation
Old Aug 21, 2006 | 11:22 AM
CVTBenhogan's Avatar
My Ride: 2006 BMW 550i "Ben Hogan's 5 Iron" SilverGrey/Black Sport, L7, NAV, CW, AS, Split FR 2003 Audi A4 3.0 CVT "Part of the Moniker" Silver/Ebony, Prem, CW, Star 17s
After nearly five months of ownership, I'm close to figuring out all the operating features on the car. I've got a couple to master, such as skipping messages on my bluetooth phone.
Can numbers be entered in Idrive during a bluetooth call, where they are recognized by the phone? I've tried and failed. This is where I-drive can be dangerous, as it tempts you to go further thru the menu while driving.
CVT Benhogan
Do you want to make a call? Yes. Did not understand your command. Please select from options? Argh, Communications! Destination Map on. F@#$ you!!!! Voice Entry Ended.
Old Aug 21, 2006 | 11:55 AM
znod's Avatar
I've had this conversation quite a few times. I am not sure I understand your question though. But, if I do, you are way more advanced than I am in trying to use the phone. I suspect that most mortals cannot enter another number via voice command, while having a "Blue Tooth conversaton." My only reason for thinking not is that doing so would require a pretty sophisitcated system, and the combination of Blue Tooth and Voice Command, IMO, is not overly sophisticated.
Old Aug 21, 2006 | 12:42 PM
hi there,
Say your listening to your voicemail in the car and your bluetooth phone is deep in your pocket. You want to skip a message, so you'd like to find some way to press a single number (corresponding to skip feature on the mobile) thru the Idrive. Can this be done? I know the new S class has the armrest located keypad integrated with its NAV, possibly for this use.
CVT Benhogan
Old Aug 21, 2006 | 03:00 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by CVTBenhogan' post='325056' date='Aug 21 2006, 04:42 PM
hi there,
CVT Benhogan
Just press the controller down while on the current call (press down while the "active call" is highlighted). From there, you'll see an option to end the call and another option called "keypad." Select "keypad" and dial away...
Old Aug 22, 2006 | 07:10 AM
Thanks Rudy.
Old Aug 24, 2006 | 08:39 AM
Rudy, worked like charm. Your the man!!!!!!!!!!!
Vman33
Mar 14, 2022 04:43 AM
CHRGRS_BMW
38
Sep 1, 2016 09:39 AM
Deano
Sep 28, 2015 10:15 AM
ucsbwsr
Sep 19, 2015 10:58 AM
