BLUETOOTH MYSTERY
Old 05-13-2009, 06:54 AM
  #21
theXman's Avatar
My Ride: 2004 530i
Originally Posted by earossi' post='837202' date='Apr 5 2009, 06:05 PM
Build date was March 2005; so, the car is a late 2005 model car. There are also other glitches in the I-drive menu. For instance, there is a screen to vary the screen "Illumination". I can get to that function and even pull up the screen that shows it adjusted in the centered position. But, there are no menu options to allow me to change that setting for screen Illumination.
There is no opiton on the Idrive to pair the phone. When I finally get down to the screen that gives me a choice between "PHONE" ir "BMW ASSIST", there are no other menu selections when you toggle to the PHONE selection.
Perplexing.
If you don't see any options to pair phone in iDrive, then you might need a software update to enable it providing that your TCU (phone module) is up-to-date. Ask the dealer to do it for free if the car is still under warranty
Old 05-17-2009, 01:29 PM
  #22
JasonH's Avatar
I have a problem with my Bluetooth but reading all the replies above I think there's something I can add that might help some people.
The Bluetooth enabling isn't in the obvious menu...it's not in UP and COMMUNICATION. It's in the main 'I' menu at the bottom.
Mine is a 2004 and won't enable but I think I've got a Bluetooth MULF module problem.
Old 06-10-2009, 03:23 AM
  #23
nljong17's Avatar
Originally Posted by earossi' post='835491' date='Apr 3 2009, 10:10 PM
Well, I still need help. I can find the Bluetooth menu but there does not appear to be any way to add a new phone. Can someone walk me through the process? I am beginning to develop a negative attitude towards the iDrive! What it needs is a "Search" or "help" button.
Any luck yet? Going through this thread I could not find the right way to access the bluetooth settings of iDrive. Annoyingly, as most people allready found out, the settings can not be accessed via the obvious communication page. Instead you have to go to the settings page by pushing the iDrive button in the main menu. Then you can select bluetooth and enable bluetooth and add new partnerships.
Just thought to add this information as to be of help for future seekers.
Old 07-28-2009, 11:23 AM
  #24
Paq
Paq's Avatar
hello,
i wonder if anybody could help me.
i managed to pair my phone to the car and it works fine, i get all the contacts etc, but when i give the idrive the command to dial a number, it makes the call but i am not able to talk unless i use the handset....i mean if i speak in the speaker the person whom im talking to dont hear me....and i cant hear him in the car sound system, i have to speak/listen in the handset.
i have an iphone 1.1.1 ( one of the firsts and im not willing to change or upgrade
thanks in advance 1
Old 07-28-2009, 11:37 AM
  #25
theXman's Avatar
My Ride: 2004 530i
Originally Posted by Paq' post='957019' date='Jul 28 2009, 03:23 PM
hello,
thanks in advance 1
The mic in your car might be broken or the wire connection is loosen. Take a look at that 1st. Its located in the overhead light module in the front.
Old 07-28-2009, 11:43 AM
  #26
Paq
Paq's Avatar
im gonna look first thing in the morning, but what about not being able to hear anything in the car sound system ?
thanks for the quick answer
Old 07-29-2009, 02:41 AM
  #27
Paq
Paq's Avatar
mic is fine...
anybody know how can i set my iphone as audio source as i read in one article ?
thank you
Old 07-29-2009, 04:37 AM
  #28
theXman's Avatar
My Ride: 2004 530i
Originally Posted by Paq' post='957835' date='Jul 29 2009, 06:41 AM
mic is fine...
thank you
If you wanted to play music from the iPhone, then you need the iPod integration kit or other similar aftermarket setup (e.g., Dension).
Old 07-29-2009, 04:51 AM
  #29
Paq
Paq's Avatar
nope, i just want to speak/ listen in the car audio system....as now i only can browse through the contacts etc i can make the call using idrive but i dont hear anything in the car audio...same with incoming calls, it rings in the car audio, i accept the call in idrive but dont hear anything ( it shows paired but cant use the phone through sound system
i dont want to use the iphone as an ipod...i just read in an article i have to set my iphone as a sound source to be able to use the handsfree option...i dont know if its true though coz i didnt find anything in the phone or car menu about this
Old 08-01-2009, 11:59 PM
  #30
puzzled's Avatar
Did you check the version of your TCU. Older version could pair and make phone calls, but voice communications did not work properly during the call, hence, the need for the correct updated TCU. I just had my BT retrofit done on my 2004 545i with 02-2004 production.
CHRGRS_BMW
38
09-01-2016 09:39 AM
Sou1b1azer
10-14-2015 06:55 PM
ka2er
07-31-2015 08:08 AM
boozooface
07-29-2015 06:56 AM
zukgod1
07-14-2015 10:19 PM
Quick Reply: BLUETOOTH MYSTERY
