Better Bluetooth Streaming
Old 06-19-2019 | 09:33 AM
  #221
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
Originally Posted by y0itzflip
here is what u need
https://www.amazon.com/Bovee-Bluetoo...gateway&sr=8-9
this worked straight out the box. shows track info (no album art however) and still uses steering wheel controls/idrive radio controls to control music if need be.
Note: This is only works if you have a USB port. Pre-LCI cars don't.
Originally Posted by wyowolf
hmmm only a 1 star review... and 4 times as expensive?
There was only one review, hardly a quorum.
Old 06-19-2019 | 09:57 AM
  #222
wyowolf's Avatar
I have both USB and Aux in center armrest...
true...
Old 06-19-2019 | 09:58 AM
  #223
wyowolf's Avatar
Originally Posted by JeffCharger
I viewed the specs in the link you provided. It appears that this is a newer unit, and that they’ve added more control to the device. It looks like you should be able to select “next track” fro the device. I had to use the phone to do this.
At 1/4 price of the other unit I think I will give this a shot...
Old 06-27-2019 | 05:18 AM
  #224
wyowolf's Avatar
Just to update, I bought the one off of Amazon, couldnt be happier... works exactly like I wanted it to for streaming music. I wish I had bought it years ago
Old 06-27-2019 | 05:21 AM
  #225
JeffCharger's Avatar
Excellent!
Old 10-16-2019 | 12:15 PM
  #226
MysticRob's Avatar
My Ride: Deep Sea Blue E61 535xi
All,
Since Tinypic is now defunct we can't access the pics from the 1st post in this thread. I'm pretty lost on how and what to do now, so I'm wondering if anyone has a decent how-to or video on completing the wiring.
I have the panel apart at rear of console but am stumped on how to proceed since I'm no electrical engineer.
Can someone post some more info on this?
Old 10-16-2019 | 12:49 PM
  #227
MysticRob's Avatar
I disconnected my AUX jack wire harness and used a 3.5 mm male headphone plug from an old set of headphones and just tapped into the harness wires. Then that plugs into the Sure board. (see pic below)
Okay, I have a 3.5mm jack that I cut the other end of off but I have no idea which specific wires from that loose 3.5mm end (there's a red, a white, and an outer ground?) need to be spliced into the aux harness wires.
Here's the aux harness connector unplugged from the aux module. Which of the red, white, and/or ground wires do I splice into the loose end of the 3.5mm connector? Black, yellow, or clear? And what exactly does each wire go to ?
Old 10-16-2019 | 12:53 PM
  #228
MysticRob's Avatar
Here's a pic of the loose end of the 3.5mm connector showing the red and white wires, and what I'm assuming is the ground wire.
Again, I'm just not sure which wires from the 3.5mm connector get spliced into which of the black, yellow, or ground wires on the aux harness wires.
Pointers appreciated!!
Old 10-16-2019 | 01:24 PM
  #229
zoom750's Avatar
My Ride: 535i X-Drive
Model Year: 2010
Not sure what you need to do, but maybe this video can help.
And this may help with the jack wiring.
https://pinoutguide.com/Home/Tele35s_pinout.shtml
Good luck
Old 10-16-2019 | 02:21 PM
  #230
MysticRob's Avatar
https://www.youtube.com/watch?v=gXOLFggCz8A
Good luck
No, I looked at that video and it's not about the rear console and aux wiring. After thinking about it though, I've come to the conclusion the left and right wiring really doesn't matter as I'll never know whether they're reversed or not. I figure the red and white go to the yellow and black, and the grounds will just go together, so I'll wire it all up that way.
After that, the only remaining question will be how to wire the power into the board from the cigarette lighter wiring. I'd hate to wire it backward and smoke the board, not that I even know if that's possible.
Quick Reply: Better Bluetooth Streaming
