03/04 to 08/04 BLUETOOTH CAN BE DONE WITH CODING! NO $$&
Old 05-10-2012, 11:41 AM
  #51
haixu's Avatar
Hi guys,
I have a 530i 03/04 and want to activate BT. I read so far and I am going to watch teh video on coding with ncs expert.
First thing first. I am going to order a cable:
BMW USB OBD Diagnostic cable INPA Ediabas DIS SSS GT1
http://www.ebay.com/itm/BMW-USB-OBD-...item4cf9b475a7
Will this work Or I need this:
BMW USB OBD Diagnostic cable INPA K+D+CAN works with DIS SSS like GT1
instead. Please let me know - greatly appreciate it.
Old 05-20-2013, 08:21 AM
  #52
Maxxone's Avatar
My Ride: 525D 2004
Can anyone give me the complete instructions how to change from Bmw prof. phone ( motorola phone in arm rest) to normal bluetooth connection for regular gsm phones ? I have a 525d 2004 with CCC-nav . PLEASE ...pretty PLEASE..
Old 05-20-2013, 08:29 AM
  #53
spediegunz's Avatar
If you are familiar with ncs expert I posted the instructions for ccc in the thread it involves adding a vehicle order and changing some parameter in a few different ecus
Old 05-21-2013, 12:30 AM
  #54
Maxxone's Avatar
My Ride: 525D 2004
I'm familiar with NCS I've done everything but it still dosen't work . In the VO I've added $633 and deleted $638 is the something else to be added or deleted in the VO? Also last night I've changed TELEFON_TYPE_C08 to say ece_phone and now I am able to get a succesfull pair but still no connection ... Any ideas ? Thank you in advance .
Old 05-21-2013, 06:27 AM
  #55
spediegunz's Avatar
Question? Did you perform a tcu retrofit or are you still using the one in your car because my car is an 04 and the tcu in my car wasn't setup for Bluetooth they really only started putting them in after 05
Old 05-22-2013, 01:15 AM
  #56
Maxxone's Avatar
My Ride: 525D 2004
It's the inital one that came with the car - 2004 e60 525d , with prof. phone factory installed in the arm rest... Update when I set TELEFON_TYPE_C08 to say ece_phone on idrive it will pair but on the comunnication menu it says "Insert Sim Card" what are the other variables for TELEFON_TYPE_C08 ?
Old 05-22-2013, 01:27 AM
  #57
spediegunz's Avatar
Ece_phone is the command for European phones change it back to what it says on my original post also try to make the change I made in post 27 to the Cappl however I'm still a little worried that you don't have a bt tcu and that could be the final reasons behind your issues because 04 was a very hard year
Old 05-22-2013, 07:40 AM
  #58
Maxxone's Avatar
My Ride: 525D 2004
I will keep trying until I'm 100% sure that it won't work ... by the way the production date is 03.2004
Old 05-22-2013, 08:05 AM
  #59
spediegunz's Avatar
Good luck my friend
Old 05-22-2013, 06:54 PM
  #60
almandee26's Avatar
My Ride: 2004 BMW 545i sport package with Mteck & M5 Rims Mpower
Default 2004 545i Bluetooth
Originally Posted by brendinernst
So I have been told by every dealer that the service bulletin that says that cars produced between 03/04 thru 08/04 cannot have bluetooth until the car has the proper TCU put in. This is a LIE I have been coding with NCSExpert for a while now and I dove into the bluetooth coding last night and I am making calls through my car today! So for anyone that has been told "no" I am proof that that is a lie. I am in OHIO and if you would like me to activate your bluetooth PM me.
I'm from New York , I have an 2004 BMW 545i would like to bluethooth it what is the next step . I was told that I have to get an upgrade . Can you please give me info on what to do .???
Quick Reply: 03/04 to 08/04 BLUETOOTH CAN BE DONE WITH CODING! NO $$&
