Remus 545i 550i Single System - In stock
Old Oct 30, 2007 | 04:01 PM
dee's Avatar
dee
My Ride: 05 545i jet blk/blk sports,sound
Originally Posted by RemusExhaustShop' post='487865' date='Oct 30 2007, 09:24 AM
We have no problems holding those mufflers in stock.
How much?
thanks,
Dan
Old Oct 30, 2007 | 05:12 PM
CampioniShop's Avatar
820 shipped
We offer 5% to all members of E60.net
779.00 shipped
Old Oct 31, 2007 | 12:18 PM
NY550i's Avatar
My Ride: Fully Loaded Monaco Blue 550i Sport
Is any welding or cutting required? does the 545i and 550i get the same muffler? same part number?
Old Oct 31, 2007 | 12:27 PM
Both are same part number. It's a bolt-on using stock hangers.
Old Oct 31, 2007 | 01:34 PM
s4iscool's Avatar
My Ride: E90 330i + E60 550i
i question whether you all ever installed this on a 550? i ask because i dont see how this could be a bolt on for the 550i. the exhaust is practically one piece from the cat back, so the stock exhaust would have to be cut off.
Old Oct 31, 2007 | 01:48 PM
According to Remus Austria, it's a bolt on.
Old Oct 31, 2007 | 02:03 PM
s4iscool's Avatar
i guess if you cut the stock off, weld a flange to the resonator pipe...then this becomes a "bolt on".
Old Oct 31, 2007 | 04:03 PM
rodybmw's Avatar
The E60 does not have a flange or connection point between the muffler and the middle resonator, so it is not Remus's fault that their muffler is not a true "bolt on", other mufflers made for the E60 are the same way. In order to install the Remus (or other mufflers) you would have to cut the stock pipe at the appropriate spot. You would then slip on the Remus's inlet pipe onto and over the car's (now cut) stock pipe, and then clamp it on. You can't see very well in this picture, but the part of the pipe that has the clamp on is slightly larger in diameter compared to the rest of the pipe so that it can slip onto the oem pipe.
I did this on my car when I installed the B&B a couple of years ago. It took a long time to cut the stock pipe since the car was on my garage floor with just a floor jack raising the rear left......not having a long enough electric saw blade didn't help either. When I decided to put the stock muffler back on I took the car to a muffler shop because it needed to be welded on. They needed to cut the stock pipe again to get a cleaner edge. With the car on a lift and the appropriate saw they cut it in less than 2 minutes. So I would recommend that you have a muffler shop do it, unless you have the right saw and saw blade so as not to butcher the oem pipe.
I think when they say "bolt on" they are just trying to say that there is no welding involved and it can be done with just bolts (clamps). So in a way it is a "Bolt On" because you could cut the pipe, slip on the muffler pipe on it and tighten the clamp's "bolts" with no welding involved.
Old Oct 31, 2007 | 05:21 PM
Always very information Rody, thanks for the clearup!
Old Oct 31, 2007 | 06:05 PM
s4iscool's Avatar
i und the meaning of bolt on, and this is not it, esp when you would need a sawzall to cut the stock pipe. The words "bolt on" give the impression that the original part can be unbolted, and the new aftermarket part "bolted" on, easy as that.
anyways, as long as people und that this is not something you could easily do in your garage unless you have a lift and experience with a sawzall (plus a number of blades, the stock pipes are quite beefy.
