Brembo Brake Calipers
My Ride: 2006 BMW 650i
hey guys ive been doing research to buy some BREMBO Brake Calipers but it seems that they dont sell it. Do you guys know where or if they do sell just the calipers alone?
My Ride: 545i Sport
Engine: N62
Brembo Rear Big Brake Kit for E60 M5
model------------------------------ yr ---piston/color ---Wheel Size----------------------------------- price ------ TMS Price call
E60 5‐Series Front (Excluding M5) 2004 > 4 B, R, S 19 380x32 2‐Piece 1B1.9002A 1B2.9002A $ 3,795.00
E60 5‐Series Front (Excluding M5) 2004 > 6 B,R,S,Y 19 380x32 2‐Piece 1M1.9009A 1M2.9009A $ 4,250.00
E60 5‐Series Front (Excluding M5) 2004 > 8 B, R, S 19 380x34 2‐Piece 1G1.9018A 1G2.9018A $ 4,550.00
E60 5‐Series Rear (Excluding M5) 2004 > 4 B, R, S 18 345x28 2‐Piece 2C1.8014A 2C2.8014A $ 3,195.00
E60 M5 Front 2006 > 6 B,R,S,Y 20 380x34 2‐Piece 1N1.9001A 1N2.9001A $ 4,250.00
E60 M5 Front 2006 > 6 B,R,S,Y 22 405x34 2‐Piece 1N1.9504A 1N2.9504A $ 4,550.00
My Ride: See sig :)
I doubt you will find just the calipers, as you do need the bigger rotors for it to work. Usually will come in a kit, unless you find some used.
My Ride: '10 Switzer "Ultimate Street Edition" GT-R
Originally Posted by louiemC' post='911304' date='Jun 14 2009, 11:54 AM
might as well get the whole thing.. brembos for 6ers are going to cost more than 5gs for all the brakes
My Ride: 2004 645cic, 20" asanti wheel with KW Coilover Variant 3
By far i think brembos is one of the best that you can find in the market. Are you sure you want to change your brake calipers? In my past i have different brake kits and they are also custom build for my car too! Is really if you are going to drive that hard or race. Otherwise is going to give you headaches try to keep up with them! Because they are made for high temptures and stop in a dime, your brake pads and rotor are going to run out fast. O yes you will know when your front wheels start shaking is because your rotors are running low and bad brake pad. A good racing pads can run about few hundreds a pair, rotors runs you about $200 each or more depending what you have cross or drill in some case they have both? I use to have BIG BRAKE KITS, 6 calipers in the front and 4 in the back, as for my Truck i have 8 calipers in the front. You will feel the different after 9 month to a year when they running bad and you wish you would have the stock back ! not sure about other, but i know i do! So for now i'm just changing wheels and basic suspension. Only if you like to race at the track all the time is not really for the looks! But if you have all time and money why not
bestofthebest
03-28-2016 02:47 PM
ucsbwsr
09-19-2015 10:58 AM
