E60 M5 Driver Scares a Good Portion of Europe
By -
e60 m5
A straight piped V10 M5 is good enough to startle most, but if you want to kick it up a notch, sliding your car around public streets is a pretty good way to intimidate people, especially if that slide happens to be right towards the folks you’re trying to scare. Thanks to the ExoticsofGermany video below, we can now experience, from a point-of-view perspective no less, what it’s like to be “that guy.”
Fill yourself with adrenaline as you go speeding through narrow, traffic-filled streets. Elevate your senses with some burnouts in front of bikers and other cars. And you can even do some half-talented slides into on-coming lanes of traffic too, if you wish. Make sure to only do it when people are around though. If a tree falls in the forest with no one around to hear it…
If you’re not able to tell by the sarcasm in the paragraph above, this video strikes a nerve. It gives a bad name to M5 drivers, and helps uphold the common belief that BMW drivers are a bunch of jerks. Well, this guy sure does an impressive job at aligning himself with that pre-assumed fact.
Via [ExoticsofGermany]
