DIY cruise control retrofit
Old 03-26-2014, 10:51 AM
adi_fox07's Avatar
Hi
What should i get coded to have full cruise control working?
A few years ago i retrofited cruise control on my e60 530d - 2005, works fine until now when i updated whole car. So when i enabled cruise control, my car going on a constant speed but i dont see anynthing on cluster.
please help me
Old 02-23-2015, 09:53 AM
Jynkky's Avatar
My Ride: BMW
hi there.
I have problem to retrofit cruise to e60 lci 525ia
I have install stalk and put $540 to fa, everything goes fine, but car says cruise control failure when I start a car, buttons and stalk work fine, I have watch it by inpa.
I have done many retrofits to 3 series bimmers without cluster change but is it truth to have to change it for this?
error code with cruise is can fault by dme-dsc-kombi.
next I will check is there pt can or not but does anybody know answer for problem?
THX
Old 03-28-2015, 04:46 AM
bmwrider2010's Avatar
My Ride: BMW 550i
on lci it is $544 not $540
Old 08-17-2016, 08:23 PM
karthik67's Avatar
My Ride: E60 530i
Hi Rostman,
Do you remember the coding you did for the cruise control to work. I have installed the stalk and the change of Instrument cluster. I can see the lever control work fine through icom. However, the cruise control does not seem to work at all.
Would appreciate your input.
thanks and regards,
Karthik
Originally Posted by Rostman
Thanks ViperRunner! Got it a few days ago.
Some photos.
To make sure if you want change the dashboard or not you need to make test number 2 to see if you have cruise-control pointer going round speedometer.
http://www.youtube.com/watch?v=SwFi6...layer_embedded
After that i've made complete upgrade of car sw and some coding and cruise starts working
http://www.youtube.com/watch?v=fD9Hu...layer_embedded
Old 04-23-2017, 05:04 PM
kenpham's Avatar
My Ride: 530i N52
Originally Posted by karthik67
Hi Rostman,
thanks and regards,
Karthik
anybody who are successful retrofit cc for e60 LCI please advise. I ínstalled stalk, replace cluster, add FA $540 to VO.
when I push cc stalk, it show on my HUD 409 instead of the real speed. It cannot work indeed.
Inty
07-09-2015 09:48 AM
kentuckynet
F10 Discussion
07-03-2015 06:14 PM
lukieno1
07-01-2015 04:37 PM
530e60
12-04-2007 08:08 PM
08-12-2003 11:41 AM
Quick Reply: DIY cruise control retrofit
