Sponsored by:
Sponsored by:
Moisture in rear pass. footwell
Old 09-18-2012, 10:11 AM
superman832's Avatar
Today I retrieved a book fromm my rear pass. footwell and it was wet. Came to find moisture on the carpet as though it was seeping in from underneath somehow. Any ideas on what it could be??
Thanks
Old 09-18-2012, 10:38 AM
sanjsanj's Avatar
My Ride: E60 530d
do you have a sunroof?
Also, undo your pollen filters, lift up the plastic covers underneath that, and check near the brake servo for a puddle of water
Old 09-18-2012, 12:10 PM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
Have you felt your front passenger footwell too? If its wet it may be your front storm/ebox drain...
Old 09-18-2012, 01:20 PM
seanjordan's Avatar
My Ride: 05 BMW 530I
Definitely check your storm drains for clogging. If it clogged up clean it immediately because it can create a costly fix. One you will not be willing to do. After you check the drain check your door seal to make sure water is not leaking.
thesalboy
04-08-2015 09:13 AM
fmusbmw
Bluetooth & Cell Phone Forum
05-14-2004 11:41 PM
fmusbmw
04-11-2004 04:13 PM
08-12-2003 11:41 AM
06-17-2003 09:38 PM
Quick Reply: Moisture in rear pass. footwell
