Replacement key question
Old 07-22-2014, 02:33 PM
antnmillie's Avatar
My Ride: I HAVE A 2004 530I MOSTLY STOCK EXCEPT FOR 22IN ASANTI AF128 BLACK, I HAVE A 6 SPPED MANUAL TRANS. IT ALSO HAS DOOR CURTAINS WHICH I LIKE ALOT. NAVI. I HOPE TO CHANGE MY SEATS TO COMFORT SOON.
Default Replacement key question
Hello all,
I currently only have one key for my 04 pre lci 530i and want to buy a spare. I've seen a lot on eBay, has anyone buy a key from eBay? If so how did it work out? Also if anyone knows where I can buy other then the stealership or eBay would be appreciated.
Thank you all
Old 07-31-2014, 07:38 AM
microswitch's Avatar
My Ride: 2006 525i
Forget about eBay or the dealer!! If you live in California...... ( Which I think you do)
Call BMW North America Key group.... 1-888-575-5397
They will send you a brand new original key already programmed to your car for only $150.00
and you will get it overnite. Dealers will charge you over $250 and ebay still requires the key to be cut and programmed...
I know because I was about to do that then I found out about the BMW key group...
Good luck
Old 07-31-2014, 09:16 AM
antnmillie's Avatar
Thank you very much I'll check it out
squints2c
10-06-2022 03:33 PM
Kasmo
05-07-2019 03:30 AM
eagle102158
05-19-2015 01:52 PM
brian1225
04-16-2004 05:59 AM
08-12-2003 11:41 AM
Quick Reply: Replacement key question
