Replacement key question
Hello all,
I currently only have one key for my 04 pre lci 530i and want to buy a spare. I've seen a lot on eBay, has anyone buy a key from eBay? If so how did it work out? Also if anyone knows where I can buy other then the stealership or eBay would be appreciated. Thank you all |
Forget about eBay or the dealer!! If you live in California...... ( Which I think you do)
Call BMW North America Key group.... 1-888-575-5397 They will send you a brand new original key already programmed to your car for only $150.00 and you will get it overnite. Dealers will charge you over $250 and ebay still requires the key to be cut and programmed... I know because I was about to do that then I found out about the BMW key group... Good luck |
Thank you very much I'll check it out
