AC basic to AC high retrofit DIY rev.3
Old 09-09-2016, 04:16 AM
  #131
mybeemer's Avatar
My Ride: BMW E60 M-SPORT 520D
Can someone please help me how to install basic lci panel in pre-lci car? when I do direct swap the a/c compressor is not working. Tried to do coding but no difference...
Old 09-13-2016, 05:00 AM
  #132
mybeemer's Avatar
should I change some cables in 18 pin plug?
Does anyone know what is the pin no 2 and 5 in lci panel for?
Old 10-08-2016, 05:13 AM
  #133
catalin2507's Avatar
My Ride: Bmw e60
What did you do with pin 2?
Old 10-08-2016, 05:14 AM
  #134
My Ride: Bmw e60
What did you do with pin 2 and 5?
Old 10-08-2016, 05:53 AM
  #135
Kim Steen Sommer's Avatar
My Ride: BMW530i E60
Dear BMW owner. I have an E60 from 2003, just typed. "Restraint systems. Functions or airbag, belt tensioners and belt force limiters faulty. ENSURE your seat belt is fastened despite the fault. What can I do? Regards Kim
Old 10-16-2016, 04:48 AM
  #136
Arkadius1984's Avatar
My Ride: 2007 520d Msport Touring LCI
Hi,
If you haven't solved your problem yet, I will try to help you. First of all tell us what car have you got - year/month of production, engine etc, as the pre LCI is a broad term, and there were some variations in the wiring throughout the years . Secondly find out what car did your LCI panel come from, as this is important as well. Some cable sin 18 pin plug need to be swapped around, but first provide all of the above information.
Regards, Ark.
Old 10-23-2016, 01:29 PM
  #137
dzwx's Avatar
My Ride: 2006 Carbon Black E60 525i Sport
blue 26 pin connector (X1527)
PIN No. Description Colour Gauge
1 - Signal, LIN BUS Blower Motor Output Stage Blue/Red 0.5
2 – Supply, AUC Sensor White/Red 0.5
3 - Signal, AUC Sensor Grey/Brown 0.5
4 - Supply, Condensation(Fogging) Sensor Blue/Yellow 0.5
5 - Signal, Condensation(Fogging) Sensor Blue/Grey 0.5
6 - Signal, CAN Bus System High Black 0.5
7 - Signal, CAM Bus System Low Yellow 0.5
8 - Supply, Refrigerant Pressure Sensor Grey/Black 0.5
9 - Signal, Refrigerant Pressure Sensor Blue/Black 0.5
10 - ------------- ----
11 - ------------- ----
12 - ------------- ----
13 - ------------- ----
14 - Signal, Electric Auxiliary Heater White 0.35
15 - Signal, AC Compressor, Pulse Width Modulated Black/Green 0.75
16 - Signal, Water Valve Left Yellow/Brown 0.5
17 - Signal, Water Valve Right Yellow/Purple 0.5
18 - Signal, Auxiliary Water Pump Green 0.5
19 - Signal, Rear Window Defroster Grey/Black 0.35
20 - Signal, Washer Jets Heater Green/Black 0.5
21 - Signal, AC Compressor Control Valve White/Green 0.75
22 - Supply, Rear Compartment Potentiometer White/Green 0.5
23 - Signal, Rear Compartment Potentiometer White/Blue 0.5
24 - Signal, Ventilation Temperature Sensor Blue 0.5
25 - Ground, Control Panel Brown 0.5
26 - Ground, Rear Compartment Potentiometer White/Brown 0.5
Old 01-18-2017, 10:55 AM
  #138
Misterbish's Avatar
My Ride: E60 530D
Hi Guys
Sorry to dig up an old post i retrofitted my LCI high panel last night following Bood's original post, my problem is now my engine fan is running full speed when i start up the car.
My pre LCI 2006 530D only came with 2 plugs so i ordered the blue plug(x1527) and double black plug(x13765), i followed Bloods instructions and everything works nice after all the coding is done except for the engine fan being on.
My question is even though i had to make up the wires for the double black plug(x13765) from pins 10 and 18, do i still have to cut the wire from pin 21 and connect them also to the double plug (X13765)
Please help
Thanks in advance
Old 12-14-2017, 03:56 AM
  #139
costty's Avatar
Originally Posted by Misterbish
Hi Guys
M
Hi!
Someone who has manage to solve this problem?
Thank you!
Old 01-28-2018, 03:59 PM
  #140
Sasa Radisavljevic's Avatar
My Ride: BMW
I've followed the instructions from the beginning I built a panel with a dual-zone climate it worked for some time all the options The AC was radio and stopped working The right button did not work for reset
Quick Reply: AC basic to AC high retrofit DIY rev.3
