ModBargains.com l N54 l Turbosmart Kompact Dual Port Blow off Valve l
ModBargains.com is proud to introduce the Turbosport Kompact Dual Port Blow off valve for the BMW N54 135i/335i/535i/Z4. The Turbosmart Dual Port Blow Off Valves are designed to install directly into your stock diverter pipe, for an easy installation. This blow off valve system is specifically for the BMW N54 engine where other blow off valves are universal. The Turbosmart Kompact Dual Port Blow Off Valve is an ideal upgrade for anyone who is running higher boost (software or tune) and a necessity if you would like greater boost response and no boost leaks.
Questions? Need Help? Give me a call here at 714-582-3330 x 8006 or ask for Alan
Benefits:
? Improved boost response
? Gives your BMW that desired "woosh" BOV sound
? Bolt on installation, connects directly to your OEM diverter pipe ? Replaces the factory plastic valves
? No more boost leaks!
? Can be used as a fully recirculation BOV or atmospheric vent
? Fits all N54 equipped BMWs
? Includes everything necessary for installation
Fully Recirculation vs. Atmospheric Vent:
The Turbosmart Dual Port BOV can either be configured as a 50/50 (progressive porting give early valve lift recirculation and later valve lift vent to atmosphere), fully recirculation BOV or 100% vent to atmosphere. Your N54's stock system is a fully recirculation design that "recycles" the blown off air back into the turbo. The recirculation design does not provide that "woosh" BOV sound, but still will provide you with all the other benefits of upgrading your BOV. The Turbosmart Dual Port system includes a special blanking plug allowing you to set it as a 100% atmospheric vent, where the blown off air will vent to the atmosphere and will produce that "woosh" sound.
[U2B]Uwrg_wQO2Lw[/U2B]
Applications:
2008-2010 BMW E82/E88 135i
2011 BMW E82 1M
2008-2010 BMW E92/E93 335i/xi
2007-2009 BMW E90 335i/xi
2008-2010 BMW 535i/xi
2009+ Z4 35i/35is
** NOTE: This BOV ONLY works with the N54 engine **
Pricing:
$498.95 + shipping $15 within the lower 48 states
Benefits:
Applications:
2011 BMW E82 1M
2009+ Z4 35i/35is
Pricing:
umnitza
Nov 3, 2015 02:58 PM
ucsbwsr
20
Sep 8, 2015 08:30 AM
srogers535x
Aug 5, 2015 08:48 AM
