changing out brake pads on 07 550i
My Ride: 2007 550i Titanium Grey Metallic - 6 Speed Manual, Sport Suspension, Premium, Cold Weather, Navigation, Shades, L7 Sound
i have done a few searches on this forum and i was not able to find a DIY for changing the brake pads. Front or rear. I have a 07 550i stock that i want to change out the brake pads myself. Any suggestions? thanks in advance. please and thank you
Uh, scroll down... there's a DYI post regarding changing the brakes and rotors and painting the calipers in this very forum section. There is no appreciable difference in the brakes between the 535i and 550i. Also, go to BavAuto's website and check their monthly newsletters. The Spring 2008 newsletter has DYI on changing the pad and rotors on BMW brakes that is excellent. Again, BMW brakes are pretty much all the same between the BMW models. Good luck.
I appreciate the heads up - i updated this with some links for anyone else
thanks- appreciate the info I will check it out now
http://forums.5serie...g-the-calipers/
the link to BavAuto's
http://www.bavauto.com/newsletter
I found this one too at Pelican parts
http://www.pelicanpa...-Brake_Pads.htm
ok guys... the rotor diy does not really get into just the pads... I pulled a bunch of pics from the one at Pelican parts
and put it together as a pdf -
my application is simply changing the stock pads for other pads. I plan on taking out the pad sensor from the pad and the part that plugs into the frame while I have the other pads on. later to put the sensor back in. anyone want to add anything? please do... I will post the pdf.. just post pics here and comments if you like and I can add them... I just want a dummies guide to pad swap for a 2007 550i...
comments on the PDF:
compressing the piston: I found it easier/safer to use a C-Clamp on the old worn inner pad to push in the piston. Perfect support. I did it with the brake reservoir open and asked someone to watch the fluid while I did it. The fluid didnt move (to my surprise)
Slipping the caliper off the rotor (after removing the guide bolts) was not as easy as it sounded. I used a rubber mallet.
I like this tool better over the c-clamps. Harbor freight!!!
adding some better pics and some notes as well. when I get back from the ny bear mountain meet I will posts that info and pics... do it once and you are all set.
TexaZ3
05-06-2015 09:54 AM
