comfort access key wont start my car
Old Dec 22, 2007 | 01:15 PM
vandal1x's Avatar
the car cant detect that i have the key in my pocket,its making me put it into the ignition. any ideas? thanks
Old Dec 22, 2007 | 01:18 PM
C's Bimmer's Avatar
Both keys? Try your other key and let us know.
Old Dec 22, 2007 | 01:44 PM
vandal1x's Avatar
the other key works(but its my wifes and has all her settings) its not a huge deal but i paid for it and would like it to work! if anyone knows an easy fix that would be great
Old Dec 22, 2007 | 02:08 PM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
There are batteries in the comfort access key fob that obviously don't recharge in the ignition like the old or non-comfort access key fobs. Likely you need new batteries. Having only had my CA car for a month, don't know the size or what the process is after the battery in terms of making sure the car recognizes it again. Check the manual or I'm sure others will chime in to help...
Old Dec 22, 2007 | 02:13 PM
DynaSpy's Avatar
My Ride: 2004 Cadillac XLR // Silver with Black Interior 2002 Lincoln LS // Silver with Grey Interior [En Route] 2008 Black Sapphire Metallic 535xi // Black Nasca Leather // 18" Star Spoke Wheels // Sport, Premium & Cold Pkg // Bamboo Anthracite Trim & Headliner // Comfort Access // Head-up Display // Navigation // Logic 7 // HD Radio // Ipod // Sunshades
I would think it's just the battery, unless you really beat on the fob it shouldn't die. It's a standard CR2032 "button" battery. You can pick one up at Radio Shack or whatever electronics store you have near you. To access the battery just depress the tabs on the fob to remove the internal key. Then take a coin and pop open the battery compartment on the back. Open the back slowly because the battery tends to pop out and make sure you put the new one in correctly. Once you replace the battery it will work, no need to do anything to get the car to recognize it again.
Old Dec 22, 2007 | 02:14 PM
Rudy's Avatar
kscarrol is likely correct in this case. Since one key works, it's probable that the other key's battery is dead.
The simplest way to prove it is to swap batteries from the one that works with the one that doesn't work and if that fixes the problem, go out and buy one CR-2032 lithium battery and you're done.
To access the battery, slide out the metal key from the end of the fob and lift up the little cover by prying it up from the center of the fob at the rear...
Old Dec 22, 2007 | 05:44 PM
vandal1x's Avatar
when i bought the car the dealer told me i had to put the key in the ignition every once in a while to charge the key? is this not correct?ill get a new battery and let you guys know. thanks
Old Dec 22, 2007 | 06:08 PM
Rudy's Avatar
That's only correct for cars without comfort access...
Before buying any new battery, just swap them to be sure that's the problem.
Old Dec 23, 2007 | 07:51 AM
vandal1x's Avatar
ok i switched the battery with the other key and the car still wont start! if i have the key in my pocket it will let me lock and unlock the doors by comfort access but wont let me start the car. any other ideas? thanks
Old Dec 23, 2007 | 07:57 AM
Rudy's Avatar
There may be something wrong with the key. Just to help eliminate some variables, try putting the battery that was originaly in the "dead" key into the one that originally worked. If that key continues to work, then it's likely that you have a bad key...
