Idle Air Control faults! HELP
Old 03-13-2012, 03:39 PM
schranzkt's Avatar
Hey guys, I need yall help on this one!
So I just finished removing the intake manifold on my 2004 525i to clean (125k miles). After spending a lifetime removing and reinstalling, I am getting two engine fault codes P1504 and P1508 (low signal to opening and closing IAC)
The car is now in limp mode (half power) and even after I keep checking the condition and functionality of the IAC, the code keeps popping up!
I had the car running and unplugged the sensor and plugged back in to see if the solenoid was working. It was working...
What am I missing guys!?
Old 03-13-2012, 03:44 PM
AchtungE60's Avatar
My Ride: E60 530i
Clear the codes and see if they come back. If nothing else changed then I would assume that you unplugged your DISA when doing the intake work correct? These codes indicated the idle control valve so make sure everything is plugged back in. IF there are codes they will clear and if they remain they will probably clear after some time or just have them manually cleared.
Old 03-13-2012, 04:44 PM
schranzkt's Avatar
I cleared them with my scanner started it up and again the codes came up.
The DISA valve only has one connector correct? I see the rod on the flap does in fact fluctuate like it should.
Old 03-13-2012, 07:27 PM
AchtungE60's Avatar
My Ride: E60 530i
Yes. If it's seated correctly. Then you have to look at the Idle control valve connector just below it. Is it seated?
Old 03-13-2012, 07:31 PM
AchtungE60's Avatar
My Ride: E60 530i
Sorry for bad snapshot but it'll do.
Old 03-15-2012, 10:21 AM
schranzkt's Avatar
yes sir you are correct. When jamming the slippery intake pipe back on it knocked the connector slightly out of line. Car runs great now.
Thanks fellas!
Old 03-18-2012, 02:28 PM
AchtungE60's Avatar
My Ride: E60 530i
Awesome. Glad to hear is good now. thanks for the response to let others know the actual issue.
gergnang
02-02-2021 07:29 AM
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
TexaZ3
04-08-2015 10:50 AM
Stranger12
04-05-2015 10:42 AM
08-12-2003 11:41 AM
Quick Reply: Idle Air Control faults! HELP
