Rotate?
My Ride: Alpine White 2010 535 M-Sport
Sounds like a stupid question but the dealer said not to worry about it..goes against everything my pops taught me.
Non-stagered Run-Flats OEM 135M wheels.
I know that there are plenty of RF enemies around here, but Im stuck with these a while so please let me know what yall think to help make these hunks of rubber last.
Thanks
Thanks
Thanks
Thanks
(1) Most BMWs tires wear in a distinct manner (front and rear set wear 'differently')
(2) IF you notice HEAVY tire wear (say on inner treads, etc) by the time you notice it it may not be a good time to rotate.
(3) Some BMWs wear the rear tires more heavily than the front (wonder why
(4) Some BMWs tires "wear evenly" - that the case, there may be no benefit to rotating except to balance front to rear tire wear. (see #3)
(5) IF you decide to rotate, and your tires set / wheels are NOT STAGGERED, rotate OFTEN (every 5,000 mi or less) and rotate only FRONT TO REAR and visa-versa. NEVER NEVER x-Rotate radial tires - Pay attention to (radial) tire rotation!!
That's my story and I'm stickin to it!
So if you do have staggered wheels, you shouldn't rotate straight across if they're non-directional tires? And on non-staggered sets I've always thought that you do cross rotate fronts to back, then backs straight to the front...
TireRack seems to back me up on this, plus some other options:
Tire Tech Information - Tire Rotation Instructions
I've never thought it would do much good to rotate them straight across, but was thinking of doing it for the heck of it, to see if I notice any different wobbles or anything...I'm feeling a little vibration at a certain speed range and thought it might help to determine where it's coming from.
166's staggered
166's staggered
166's staggered
166's staggered
05Mdriver
08-24-2015 05:41 AM
houbmw
07-16-2015 05:48 PM
