Noob question about 19"s
i'm about to purchase
19"
19x8.5 front
19x9.5 rear
All have 35+ offset.
will this fit my 2004 545i?
Tire set up could be
Front
245/35/19 or 255/35/19
Rear
285/30/19
295/30/19
What would be an ideal set up for the tires as well?
Please help.
Thanks,
19"
19x8.5 front
19x9.5 rear
Front
Rear
285/30/19
295/30/19
Please help.
Thanks,
wheels will not fit your 545i directly. if you want to have those wheels you will for sure need spacers. those offsets are meant for an XI AWD E60. as for tires for those dimensions of wheels, recommended sizes would be 245/35/19 and 275/30/19.
My Ride: 09 550i 6sp M-Tech. 18mm spacers rear, 8mm front. Dinan intake and Stage 2 tune. Tinted tails, M5 OEM lip spoiler.
08 Z4 3.0si Black on Black with Beige top. Removable hardtop. (Hers)
06 Volvo S60R Heavily Modded!! Gone and missed.
My Ride: 2003 540iA M Sport
No, you need spacers like these. They are hubcentric, but also push the wheel out closer to the edge of the fender.
BMW E60 545i N62 4.4L > Wheels > Spacers > ES#205206 BMW 15mm Wheel Spacer & ECS Conical Seat Bolt Kit - ECS#255KTWB
15mm spacers and longer bolts will give you an effective ET of 20mm (35-15=20) which is good for a 2004 545i.
Ideal tires for your car would be
245/35/19 front and 275/30/19 rear
Hope this helps.
JP
Hope this helps.
JP
aqualibrium
07-21-2015 03:11 AM
