Installing e60 M5 Wheels on '10 535xi Sport!
Old 06-15-2018, 07:42 AM
JMD535's Avatar
My Ride: E60 535xi Sport, MHD Stage 1 Tune
Model Year: 2010
Default Installing e60 M5 Wheels on '10 535xi Sport!
Ok, so I have purchased a nice set of e60 M5 wheels for my 535xi Sport project,...you know the one! It's my project car that I want to build up as the '10 version of the F90 M5,..wannabe! Thus far, I have MHD Stage 1, and I plan to get to Stage 2,..but with larger Catalytic converter,....as I must be smog legal in VA. I digress,...so, I have my e60 M5 wheels,...Style #166, and they have regular valve stems, which also means they don't have TPM sensors. So, the first step in mounting the tires will be to source a set of TPM sensors. I'm thinking I need to get a set of TPM sensors for a 2010 535,...that will definitely mount on BMW Style #166 wheels!
Any recommendations would be greatly appreciated.
Old 06-15-2018, 08:04 PM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Why have any sensors at all? Not worth the cost and hassle.
Old 06-15-2018, 11:50 PM
JMD535's Avatar
Model Year: 2010
Hmm, that's a thought! But then again,...I'd be peeping at a glaring TPMS warning light! Plus,...at time of State inspection,...the vehicle most likely wouldn't pass because of the TPMS light being on. But thank you all the same....
Old 06-16-2018, 04:23 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
Early E60s use ABS/DSC controller to detect flat tires, later E60s have a TPMS sensor integrated into the valve stem. If you leave them out, you're going to be driving around with a TPMS fault staring at you every. single. time. you drive the car. Annoying to say the least.
Old 06-16-2018, 07:25 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
TPM sensors are the least of your worries. I didn't think OEM 166 wheels would fit an xi because of the offsets. BMW wheel style 166 | BmwStyleWheels.com
Your're going to run into some serious problems.
Old 06-16-2018, 11:04 AM
Model Year: 2005
Engine: N62
Ah, the joys of modifying!:rolleyes
Old 06-16-2018, 11:31 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
I have 166 reps on my xi, so where there's a will, there's a way.
Attached Thumbnails Installing e60 M5 Wheels on '10 535xi Sport!-166reps.jpg
Old 06-18-2018, 05:49 AM
JMD535's Avatar
Model Year: 2010
Well, I had the idea of making a wanna-be-look-like E60 M5,...sort of anyway. So, I searched the net and found this video:
. I then created a Tire Size spreadsheet in Excel,...to capture the difference in circumference ratio between the Front and Rear tires and the revolutions per/mile difference based on data from the Mfr (source: Tirerack). I discovered the following:
e60 (2010) 535xi Sport Stock C-Difference = .138 Revs per mile difference = 3
e60 (2010) M5 Stock C-Difference = .377 Revs per mile difference = 3
F10 (2013) M5 Stock C-Difference = .334 Revs per mile difference = 0
F10 (2012) 535 Sport Stock C-Difference = .434 Revs per mile difference = 3
F10 (2012) 535xi Sport Stock C-Difference = .0 Revs per mile difference = 0 (Same size tires all-around)
The Setup I'm considering: F/ 245/35/19 R/285/30/19
e60 (2010) 535xi Sport #166 / 19" Wheels C-Difference = .138 Revs per mile difference = 3
The tires sample I used on Tirerack registered the same "Circumference",...however, my spreadsheet still shows a 3 miles in revs per mile (805 vs 808),...which is the same for the Stock setup.
Just for kicks,...this data shows a 10 revs difference fo the e60 550 running 245/35/19 // 275/30/19 No diff in Circumference,...but 805 vs 815 revs per mile.
Note, the tire used for the comparison was the Continental Extreme Contact
That said, what tire combo size are you running? Are those 19s,...or 18" reps?
JMD
Old 06-18-2018, 05:55 AM
JMD535's Avatar
Model Year: 2010
Looks Good! I see the Style 166 wheels are on several models via the link,...the question is,...are those none e60 M5 BMWs running OEM e60 M5 wheels,...with same or different tire size combo?
JMD
Old 06-18-2018, 10:35 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
In none of your calculations are you taking offset into consideration. That will be your biggest issue with OEM M5 wheels on an AWD E60.
Quick Reply: Installing e60 M5 Wheels on '10 535xi Sport!
