e39 m5 rims/tires onto E61 530iXT
My Ride: 2001 M5, 2010 e61 / 535iXT Automatic
Model Year: 2001, 2010
So... since I have an E39 M5 which I am considering a big brake kit (which means new rims to fit perhaps) and a 530iXT which is currently running 17x7.5s -- thought it might be cool to transfer the OEM rims/tires onto the wagon? Hate to have the M5 rims sitting in the garage.
Thoughts?
Thoughts?
Check and verify the spec for the E39 wheels you have, it's all about high/big offset/ET number for the E60 xi/AWD/x-drive model and also E60 model uses 72.5mm center bore hub size AFAIK E39 bigger so you'll need hub ring.
GL!
GL!
Thanks -- It's never as easy as we would like....
ET 20 and a 74.1 center bore. Guess they will stay on the M5 until ready for another tire change. I'll concentrate on finding a good deal on used ones for the 530iXT.
Pretty steep learning curve for me here, usually just go stock, but the 530iXt 17x7.5 look like a matchbox toy.
