BMW Stlye 95's Spacers?
Old 06-29-2016 | 12:36 AM
shawn.ahmadi's Avatar
My Ride: 530i
Default BMW Stlye 95's Spacers?
I never know where to post these type of questions so my apologies if its the wrong section lol!
I just picked up some style 95s and was wondering if anyone else on here has experience running these will coil overs? I like my car as low as I can get it but unfortunately I cant lower it as much as I want as the coils rubbing against the tire but im hoping a 5mm spacer will do the trick.
the fronts are 19x9 and rears are 19x20
I have 15mm spacers and 20mm that id rather use as I don't wanna spend more money lol but do you guys think they'll fit?
Old 06-29-2016 | 11:31 PM
My Ride: 530i
well for future reference if anyone else ponders this question lol,
I managed to get them fitting perfectly with 15mm spacers in the front pushing the wheel to a 19x10.5 as for the rears you might be able to get away with a 10mm spacer with out having to roll your fenders but better safe then sorry and roll with a 5mm and youll be pushing 19x10.5 in the front and rears
Old 09-27-2016 | 12:46 PM
SimpleE61's Avatar
My Ride: 530XI Touring
Car looks great! I was looking to get a set of style 95 for my 530xi wagon and found a 19x10 square set. I see that you put a 15mm spacer in the front which doesn't change the size to 19x10.5 but lowers the offset 15mm. Effectively you are now running 19x9 +9 offset. As for the rears did you use or spacer? In you comment, you stated that you might be able to run 10mm spacer in the rears but was sure if you did.
Indiana
10-15-2015 12:30 PM
keno75
09-24-2015 06:47 PM
gonzo40
26
04-15-2005 08:26 AM
brian1225
04-16-2004 05:59 AM
Farbton
19
10-22-2003 11:21 PM
Quick Reply: BMW Stlye 95's Spacers?
