Aftermarket Wheels and suspensions for Xi
Old 08-02-2012, 07:52 AM
  #661
huntington's Avatar
My Ride: 2003 BMW 325i 2008 BMW 535xi Touring 2005 Lexus GX470 2000 Audi A4 1.8T
Originally Posted by norsecarnut
I concur based on my tire clearance and this from the e90post calculator:
my wheel is 8.5" ET 29, tire 245/45x18 compared to the one above.
"7mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 5mm"
However, if m5 fender liners were used, with his m5 fenders, then there may be just barely enough to not scrub. We did a scrub test at full turn and found it at the max, and that's without any driving compression like in a corner weighting the front which would reduce the clearance more.
BTW, my concern is not for the fronts to clear, but for the rears. If the fronts don't clear, I'll modify the fender liners & hopefully get a few MM of clearance
Old 08-02-2012, 11:48 AM
  #662
jcantanixon's Avatar
Originally Posted by alexio
you will also have a severly reduced turning radius on the front with the sizing you're looking at as the edge of your tire will rub in the inside of the wheel well. others on this site have tried many different sizes, but it's always interesting to see people dramatically push the envelope.
I can't comment on the front outside edge, but I don't think he will have any issues with the front inside edge of his tires hitting the inside of the wheel well if he's at stock height. I'm running an equal sized tire (245/40/19), with almost no clearance between the wheel and the strut (19x9 et48) and it doesn't rub the liner at full steering wheel lock.
Old 08-02-2012, 04:45 PM
  #663
huntington's Avatar
Well look what just showed up
Now just waiting on the wheels...
Old 08-03-2012, 08:53 AM
  #664
constant's Avatar
Just as an update, got a chance to mount a 255/35R19 on a 19x10" rear, +25mm offset wheel. It just barely clears on the rear of a 535xi wagon. The fender may need to be rolled just a tiny bit, but I plan to avoid it if possible unless I see evidence of rubbing. Reference post #575 in this thread for wheel test fit.
Tire widths do vary a lot between brands (even with the same size). For this test, the tire was a General G-Max AS-03 255/35R19. The rounded tread shoulder tucks in the fender nicely on this tire.
Old 08-08-2012, 06:30 AM
  #665
itz MURDAH's Avatar
My Ride: 06' BMW 530xi
Is it possible to run a 9.5 or 10 width wheel in the front? I have m5 fenders so it gives me some extra room
Old 08-10-2012, 11:55 PM
  #666
bighead2267's Avatar
I recently found a local deal. The spec as 19x8 with 28 front and 19 x10 with 38 offset. I may not plan to change suspension as I don't want a huge gap(non m). Do you all expert think the setting will work without rubbing? Mine car is 08 xi.
If the setting work. What kinda tires should I get? 225 30 19 on the front and 285 30 19 will work?
Thx
Old 08-14-2012, 01:04 PM
  #667
team23jordan's Avatar
My Ride: 12 VW Passat TDI 11 Subaru STi Sedan (GONE) 09 E60 XI 06 E46 M3 (GONE) 05 Subaru LGT (GONE) 00 Ford Lightning (GONE)
After playing with some numbers on 1010tires.com
it looks like these sizes will be perfect
225/50R17 Search TiresTire 1 - 245/35R19 Search TiresTire 2 - 285/30R19 Search TiresTire 3 - 235/40R19 Search TiresTire 4 - 265/35R19
Old 08-15-2012, 06:24 AM
  #668
crypto's Avatar
Well I will make it official that there is a sweet option for the E60 XI/xDrive from MORR.
MORR VS8.2 wheels absolutely fit the XI perfectly. They advertise it as such, so no real surprise. From what I've seen too -- it appears the E60 XI and the E9x 335i have about the same offsets. I believe MORR is changing some things around but you can basically get the "3 series fitment" (non-M3) and they fit the E60. I just put on and am now driving around in this setup:
MORR VS8.2
Front: 19x8.5 ET35 with 245/35/19 @ 35 PSI
Rear: 19x10 ET36 with 275/30/19 @ 39 PSI
You can get the 20" from them in a non-staggered setup as well.
Old 08-15-2012, 02:03 PM
  #669
MORR VS8.2
nice choice. is your XI lowered? doesn't feel 4x4 look at all.
Old 08-16-2012, 06:53 AM
  #670
crypto's Avatar
yea so funny thing is my car seems to sit lower than with my stock wheels. I was expecting the gap to look bigger but it's really not that bad at all. it is not lowered and I do not have the sport suspension or anything non-stock in that department. looks good for just throwing the wheels on eh?
Quick Reply: Aftermarket Wheels and suspensions for Xi
