Aftermarket Wheels and suspensions for Xi
#571
As you can see at the front, that's about the max without rubbing on hard turns or simply poking out and looking silly. If I were dropped, it would be running into the top of the fender for sure. The rear however could take a 10mm and be fine but loaded heavy on trips I think I've heard the tire scrub the fender liner upon hitting a good dip at speed. It's only momentary of course due to the auto leveling air suspension.
![](http://jwestproductions.com/direct/535/e61.wheeloffset.jpg)
#573
Definitely no drop needed there
If I had a wagon, I would've prolly gone that same route with mine - you get to keep the more compliant ride of the stock suspension, and the look of filled-in fender wells
#575
My contribution to this thread: test fitting a 10" rear wheel on a 2008 535xi wagon.
Wheel specs: 19x10", ET25 offset. No tire on rim due to test fit. I also mocked up some tire profile templates out of cardboard to see what size tire would fit best. From the mock ups, I would most likely choose a 265/30 or 275/30 tire. I made up a template of the 275/35R19 tire, which is a slightly taller sidewall some people run. On an ET25 rim, I think this is a no-go.
Thought these pics might help anyone looking to fit an aggressive, wide wheel & tire on the rear of your xi. I would say an ET30-ET35 19x10" wheel would be just about perfect on the rear of an xi, the ET25 will require a fender roll and a slight stretch on the rear tire.
Wheel mounted:
![Aftermarket Wheels and suspensions for Xi-img00758-20120317-1406.jpg](https://5series.net/forums/attachments/tires-wheels-52/131332d1482364520t-aftermarket-wheels-suspensions-xi-img00758-20120317-1406.jpg)
Wheel lowered to compressed (normal) ride height:
![Aftermarket Wheels and suspensions for Xi-img00759-20120317-1406.jpg](https://5series.net/forums/attachments/tires-wheels-52/131338d1482364520t-aftermarket-wheels-suspensions-xi-img00759-20120317-1406.jpg)
Inner fender clearance:
![Aftermarket Wheels and suspensions for Xi-img00761-20120317-1406.jpg](https://5series.net/forums/attachments/tires-wheels-52/131339d1482364520t-aftermarket-wheels-suspensions-xi-img00761-20120317-1406.jpg)
Approx 2.5 fingers of clearance on the inside (maybe 1.25" or so):
![Aftermarket Wheels and suspensions for Xi-img00762-20120317-1407.jpg](https://5series.net/forums/attachments/tires-wheels-52/131340d1482364520t-aftermarket-wheels-suspensions-xi-img00762-20120317-1407.jpg)
View from behind:
![Aftermarket Wheels and suspensions for Xi-img00757-20120317-1403.jpg](https://5series.net/forums/attachments/tires-wheels-52/131341d1482364520t-aftermarket-wheels-suspensions-xi-img00757-20120317-1403.jpg)
View from above:
![Aftermarket Wheels and suspensions for Xi-img00763-20120317-1407.jpg](https://5series.net/forums/attachments/tires-wheels-52/131342d1482364520t-aftermarket-wheels-suspensions-xi-img00763-20120317-1407.jpg)
View underneath:
![Aftermarket Wheels and suspensions for Xi-img00775-20120317-1412.jpg](https://5series.net/forums/attachments/tires-wheels-52/131343d1482364520t-aftermarket-wheels-suspensions-xi-img00775-20120317-1412.jpg)
Rear quarter view:
![Aftermarket Wheels and suspensions for Xi-img00765-20120317-1408.jpg](https://5series.net/forums/attachments/tires-wheels-52/131344d1482364520t-aftermarket-wheels-suspensions-xi-img00765-20120317-1408.jpg)
Checking tire profile of 265/30R19:
![Aftermarket Wheels and suspensions for Xi-img00767-20120317-1409.jpg](https://5series.net/forums/attachments/tires-wheels-52/131345d1482364520t-aftermarket-wheels-suspensions-xi-img00767-20120317-1409.jpg)
w/ 275/30R19:
![Aftermarket Wheels and suspensions for Xi-img00768-20120317-1409.jpg](https://5series.net/forums/attachments/tires-wheels-52/131346d1482364520t-aftermarket-wheels-suspensions-xi-img00768-20120317-1409.jpg)
w/ 275/35R19 (+1 sidewall height) May be too risky, tire would likely hit fender on big bumps:
Wheel mounted:
View from behind:
View from above:
View underneath:
Rear quarter view:
w/ 275/30R19:
![Aftermarket Wheels and suspensions for Xi-img00773-20120317-1411.jpg](https://5series.net/forums/attachments/tires-wheels-52/131347d1482364520t-aftermarket-wheels-suspensions-xi-img00773-20120317-1411.jpg)
#576
most important to me would be seeing the inside upper edge where the tire is going to scrub the heck out of the fender liner. The 2" at the rim is fine but the fender liner tapers in and then when the suspension is compressed it will get even tighter, while lowered off the jack, and then more when hitting dips in the road.
nice idea with the tire template.
10" at et25 is out further than I would have expected.
#577
The xi wagon has the advantage of rear air suspension, so I could always raise the height slightly by adjusting the sensor arm also.
With all 3 templates, none would rub on the inner liner. But then again, this is with an ET25 where there's about 1.5" of clearance on the inside.
#578
If you want to make your own tire templates, just type in some tire sizes into the calculator here: http://www.1010tires.com/tiresizecalculator.asp
The tire width and sidewall heights (in inches & mm) will be listed for the tire sizes you choose.
#579
Whew, just went through all 37 pages! Great info here! I'm a new 2008 535Xi owner coming from owning a 2001 330Ci. I've been a long time member of E46Fanatics and no stranger to modding... but wow, the Xi seems like a particular beast!
So maybe I've missed it, but I have not seen anyone here with an E60Xi running the Alufelgen CS7s (seen many SF-71's). Here are the specs I'm looking to purchase:
FRONT: 19" X 8.5" ET35, 245/35/19 tire
REAR: 19" X 9.5" ET35, 275/30/19 tire
What do you guys think? Any recommendations/suggestions/comments? Thanks for your help!
- Justin (Lugnut2683)
![](http://fmartinez001.smugmug.com/Cars/BMW/i-RrdpXdN/0/L/front-full-2-L.jpg)
![](http://fmartinez001.smugmug.com/Cars/BMW/i-45TZ99B/0/L/front-side-L.jpg)
![](http://fmartinez001.smugmug.com/Cars/BMW/i-xKc6TRz/0/L/low-rear-L.jpg)
![](http://fmartinez001.smugmug.com/Cars/BMW/i-KzPNSb5/0/XL/side-full-XL.jpg)
#580
New guy here with a new to me 08 535xi with the sport package (staggered 18s stock susp.) I've read all 39 pages a couple of times. Great info.
I would prefer not to lower my car yet but want new skins.
So options:
1) 19s staggered w/ 4x4 look. How bad is it in person? A couple more pics please
2) #1 and increase the side wall. I saw the pics. Not bad.
3) 20s. Some where in this thread someone mentioned 20s would fill up the wheel gap better. Is that true? Could anyone post
a picture w/ 20s no drop on an xi. I have seen a coupe pics but not sure if they were stock susp or not.
Thanks
So options:
Thanks
