2010 e61 335 xdrive fitting check for style 613 OEM 36117848573
Hi All
I'd like to fit these wheels on all four corners, the rear fitment for the 650i at an offset of 44mm looks like it works for the e61 xdrive
New wheel
Make BMW
Model 650i
Year 2014, 2015
Bolt Pattern 120mm
Center Bore ------ I think is 72.6 --------
Lug Nuts 5
Offset 44mm
Diameter 18"
Width 9"
Finish Silver
Wheel Type Alloy
OEM Part # 36117848573
Style 613
And for the e61 2010 xdrive I think stock is et43 for 17x7.5 - 225 x 50x 17 but I am not at all sure about the bolt size which despite the PCD being the same appears to be different between the cars and possibly the center bore is 72.5 not 72.6
Has anyone tried this, can anyone confirm I got the specs right, what did I miss ?
New wheel
Make BMW
Model 650i
Year 2014, 2015
Bolt Pattern 120mm
Lug Nuts 5
Offset 44mm
Diameter 18"
Width 9"
Finish Silver
Wheel Type Alloy
Style 613
PelicanParts.com
Aug 13, 2015 01:45 PM
Thomas the Swede
Sep 13, 2003 12:22 PM
