Suddenly all 6 injectors throwing code, then went away.
Old 11-02-2024 | 12:41 PM
Jonasand's Avatar
My Ride: Full option 530xd
Default Suddenly all 6 injectors throwing code, then went away.
First cold day around - 2c and started the e61 530xd, let it idle for 5min and went... When i reached around 90kmh it shut off. Restarted and reached the store, checked code. Was for injector 5..its new bosch since 3months.
Cleared it and went home, all god at higher speed untill i accelerated.. Died and showed all injectors actovation. Died one more to home.. All in 10min
Checked with protool, battery voltage, alternator, fuel temprature aswell engine temp.
All good, all was as it should.
Went for another drive... Doesnt matter now how i drive.. I can put it to the floor from standing still up to 200kmh if i want.
Just keep on going.
What should i check... What could it be..
Bad fuel?
Old 11-02-2024 | 03:50 PM
donpb's Avatar
My Ride: '06 530i N52
Intermittent issues usually need to get worse before you can actually fix them. That makes them difficult to troubleshoot. The car is making adjustments, but it can only do so much. And your temperature environment is adding an extra challenge as well. I would try reseating things (can't say what exactly), especially things that were recently replaced.
Old Yesterday | 03:44 AM
Jonasand's Avatar
Well its weird, all looks good.
Went for a drive today, no problem.
It just make u not trust the car, and when going highway speed and realising it can die and hold up the whole lane isnt any good feeling.
Whopperoni
06-22-2024 04:53 AM
Jonasand
12-10-2022 05:30 AM
kujtim_j
01-13-2019 11:40 AM
JohnnyTurbo
04-10-2016 06:22 AM
phocker
10-09-2008 12:38 AM
Quick Reply: Suddenly all 6 injectors throwing code, then went away.
