E61 Rear Quarter Window Sun Shade Removal
Old 05-02-2023, 02:31 PM
gwillodson's Avatar
My Ride: 2006 530XI base
Default E61 Rear Quarter Window Sun Shade Removal
Has anyone removed the vertical housing that holds the quarter window shade from their E61 (without breaking anything)?
The only diagrams I've found are for the E60. One shows upper and lower clips, and states that the upper clip can be pried upwards to release the shade.
I can look into the housing thru the shade slot, and actually see the upper and lower screws, and neither of them is holding a clip.
UPDATE - I just ran across a pdf (again an E60) that shows prying the housing off from the leading edge (no screws involved), but it hasn't budged so far.
I'm afraid it's going to break. What's the trick?
Old 07-13-2024, 12:51 AM
Probation Members
Ritz's Avatar
My Ride: BMW E61 530Xdrive
I did remove mine. You'll need to pry it on the side, and it will pop out. I recommend to lower the window first.
jadedj
09-16-2018 01:03 PM
eoxaal
10-14-2014 08:02 AM
DMan7
DIY: Do It Yourself
07-28-2011 11:02 PM
nell
04-23-2010 09:23 AM
DPN
DIY: Do It Yourself
11-26-2008 02:05 PM
Quick Reply: E61 Rear Quarter Window Sun Shade Removal
