Fault Code 2E9F
Old 01-18-2019, 11:26 AM
ericono's Avatar
My Ride: 1985 M635, 2010 e61
Model Year: 1985
Default Fault Code 2E9F
I called myself searching but didn't find a lot. It is sounding like this is telling me that the oil level sensor is going bad, but is that others' experience. Any other possibilities?
Thanks,
Eric
Old 01-19-2019, 11:03 PM
pole's Avatar
My Ride: BMW E61 530d
Engine: 3.0d
could also be that you have moisture inside the engine, which points towards a bad Crankcase Ventilation Valve, breather or whatever it's called, that moisture messes up with the sensor reading, thus throwing a fault in that sensor.
does the oil sensor work? I mean can you check the oil level from iDrive?
what type of oil do you use and what engine do you have?
Old 01-23-2019, 06:15 AM
ericono's Avatar
Model Year: 1985
Thanks for the response. Sorry I forgot to list my car and engine type. It is a 2010 e61 535xi with the n54 engine.
I can check the oil level on iDrive. Shows as full.
I'll have to double check the type of oil, but it is the factory spec oil.
So is the CCV looking like a likely cause or a faulty sensor or something else?
Thanks again,
Eric
Old 01-23-2019, 06:40 AM
pole's Avatar
Engine: 3.0d
ccv should be changed anyway at regular intervals, also you could replace the oil sensor as it's cheap, at least you can rule them out...
knklhead
01-08-2015 03:20 PM
ROMAL
12-07-2011 11:25 AM
edin535d
10-02-2009 01:04 AM
Blanco545i
09-19-2007 05:11 AM
Quick Reply: Fault Code 2E9F
